matt_i
This is very cool and will be very useful in the future! I had never considered inverting standard trolleys to be the bogey wheels
So here's an idea to pollute your mind...
Consider you are almost to the point of having a power-travel bridge. You just need a long shaft which could be a tube like even a thinwall conduit for the loads involved and some traction wheels of same OD...could be caster wheels or the like.
You can drive it from anywhere but center would be best to equalize the torsion. If you find the proper chain sprocket you can slip it on and weld it into best position. There have to be some supports for the long shaft but they don't need to hold a lot of weight. Some simple tube steel arms.
You mentioned VFDs and gearboxes, you don't need an exotic VFD, just a 1/4hp motor will do this job and some reduction, some via the chain drive and some via the gearbox and some via the VFD. Its a perfect application to go after two or three travel speeds via setpoints programmed into the VFD itself....just have to have it respond to the proper button or input.
In any case you'd have a crane up there with the big boys and you wouldn't have to worry about racking. A big crane would have more distance between the end trucks but this costs you access to things set near the walls.
Keep the pics coming please, fantastic build!
...Steve
