Not this again. What’s this tool?
Jack84
Netherlands
Recently I picked up a Mercer dial gauge, it’s old but I can’t figure out what it was used for. Pretty sure it ain’t a bore gauge though because the measuring cone and bits would marr up the surface of the bore you’re measuring.
You also need quite some force to actuate it, it has a strong spring in it. Unlike any other dial gauge I know.
Any help identifying it would be appreciated.
Strouty
Southern Maine
Something for hardness? Could the dial indicate something that gets extrapolated? Can we get a picture of the dial? Also I am not doing the obvious search, I find this to be more interesting to try and figure it out by the tool itself.
J
Jack84
Netherlands
I added a picture.
The dial is just a normal, nothing special.
I did a search already and can’t find anything useful.
Provincial
Near Salem, OR
It looks like a crankshaft distortion gauge. They are put between the throws of a crankshaft, which is then rotated in the main journals. If the gauge indictates movement, it means that the main journals are not in line, and the crank is having to flex as it rotates.
J
Jack84
Netherlands
Thanks! This one had me baffled. Explains the spring pressure and hardened tips.
Found an image of it, easy when you know what it is.
isb cornbinder
I found a similar tool on Craigslist. I was told the tool I bought is to measure connecting rod to crank accuracy. More of the same thing, maybe a little different.
The tool I bought is made by Ruston Hornsby for use on the engines they built.
My Ruston is a Canadian Elevator Engine. 640 cubic inches single cylinder Diesel.
J
Jack84
Netherlands
Nice find!
I love those oddball tools from yesteryear.
Sevenhills1952
Virginia
And you know these quality tools were very expensive new. Really nice things!
Sent from my SM-S320VL using Tapatalk
