michael murder
Re: Nut & Bolt Storage
I had a bunch of 3/4" scrap lying around and made these.
Burgerkong
Markham, Ontario, Canada
Jmatlock88
My Lyon cabinets with Harbor Freight bins and a file cabinet (formerly used for movie film) with Schaller Bins.
jsomtiques
spring valley, ILL
GirlnAgarage
Texas
Nothing fancy now, just sorted by size and baggied and thrown in the bottom drawer of my box.
michael murder, I really like those bins :thumbup:
incurablescrounge
Janesville, Wisconsin
Here is what I scored. I had many other cabinets like on this thread until I saw this. Addressograph card cabinet. 133 drawers, roll up doors, 6' tall, 4' wide, 2' deep. Holds almost everything. Big stuff is a little problem.
ADSR
Hands down, best ive ever seen.
Well done.
IMCA38
Bennet, NE
I recently got the big metal cabinet at an auction for $60. Presently filling that with assorted hardware. I keep my nuts and bolts in the wooden cabinet that my dad and I made 15+ years ago. Each horizontal row is a different size. I have 1/4" through 3/4" and the last row is just larger stuff that I don't have in large quantities.
Mattlt
MN
I use 1/2 gallon plastic juice containers that I cut to a uniform size with the table saw. Very similar to using oil jugs. Cutting them with the saw seems safer to me than using a utility knife.
Built a wooden frame with a plywood bottom to act as a drawer. Then used angle iron for drawer slides.
Food for thought... If you are really cramped for space, remember that round containers (PB jars, coffee cans, etc) are not the most efficient use of space. You would be better off with square or rectangular containers to fill the shelf / drawer space more efficiently.
I'm also big on using uniformly sized containers for some reason. :)
PCO6
Newmarket, Ontario
Mattlt - I use juice bottles too. I used to cut them down on my table saw but I still had to trim them slightly due to the rough edge that was left by the saw blade. Another GJ member (sorry I can't remember his name) came up with a simple jig made out of wood and a box cutter blade.
I don't have a picture of the jig but I just screwed 2 short (about 6") pieces of 2"x4" together to form a right angle. I set the length of 1 piece at 4" being the height that I cut the bottles down to. I then screwed the blade to the end face of the 2"x4" so that the blade is in a position to cut the bottle. It's fast, accurate and safe.
View media item 33184
Fishplate
Athens, Georgia
When I cut PVC pipe on the table saw, I turn the blade backwards. Makes the smoothest cut you've ever seen.
Dunno how it would work with a plastic bottle, but I like your storage and might try it myself....
mdbeck1
Norman, OK
I've been told that you can use a book and a razor blade to make the cuts as well. Place the razor blade on a specific page next to the spine (sharp end facing away from the spine and exposed) and rotate the plastic container against it. It should cut the plastic bottle the same height all the way around.
TheClaw
Chicagoland
Garage sale find with SAE nuts bolts stuff.
From an ACE Hardware that was closing with deck screws, nails, small parts and hardware
More from the ACE with small metric nuts and bolts, cotter pins, misc ****.
Jeff
woodrail
Lorain, Ohio
After years of blowing sawdust out of the bins, I decided to put this harbor freight rrack in a sliding enclosure.
shephd
va
For some of the bins with random assortments - I took a photo of the entire bin - and have a flip-card by the bins so I can quickly look to see what bin something random is in.
It's obvious now that you've said it :lol_hitti
Seriously, for me this is the best idea I have ever gotten from here :beer: THANKS!
48windsor
Olympia ,Wa.
Jackolsen what a sweet set up. But back to the thread , nice drawers. I just got rid of some similar . Didnt have the housing cabinet . but worked good on shelves
Linda@Lista
Holliston, MA
I use the Stanley (or Mastercraft/Canadian Tire Brand) storage bins. The bins are removable and adjustable - so you can have a mixture of small, medium and large. ...
Thanks for using Stanley storage bins, I love the setup! There are some cool (and creative) cabinets and organizers in here. Here’s one of my favorites an auto dealership is using.
Linda@Lista/Vidmar
cokeb5
Boise,ID.
I have that same cabinet, the small blue electrical boxes work great for small parts, just need to trim a little off the top and there only .18 each.
911mike
michigan
Linda@Lista/Vidmar
After YEARS of storing hardware I feel this is the best and fastest way to organize and find hardware. I'm up to 10 draws and it just amazing how easy it works.
nmpontiac
I have some software that I use for lots of filing stuff that also works pretty well for the various bins, etc. I use for my aircraft and normal hardware,electrical stuff, etc. - it's called "Paper Tiger" and can be changed on the run if you want to move stuff around, uses keywords (like "#6 Dzus buttons") for quick searches.
nicksnothereman
In the Mojave
I like the stack-on stuff for whatever reason. Probably because it's cheap and fairly durable. Sometimes I find their stuff on clearance but usually only those horizontal boxes but those don't really "stack" that well. :sad:
incurablescrounge
I have a friend who works part time at Ace Hardware. All of their nuts and screws come in a variety of small cardboard boxes. After filling their inventory, he would give the boxes to me. If you don't know anyone, it wouldn't hurt to ask.
don long
southern california
Here is my assortment of storage containers for all small in my shop
I really like the flip down plastic boxes for the misc small stuff because I can see what I have at a glance
dittle fart around
Vancouver, Washington, USA
The Parkrose hardware store in Vancouver had these slide racks. Lots of small parts and you could see what you were getting.
View media item 35353
BearCuda
Martinsburg,WV
I have something like that on top of my main bench. I use it for all the kinds of little miscellaneous stuff you want to have on hand. Nice to have the little drawers that way so it doesn't become one big junk drawer (alhtough I'll admit, I've got a junk drawer, too). I had to cut one whole row out of the thing to make it fit, which was a bummer. But it comes in handy.
marty_p is right, the index card type can often be had for next to nothing, where the industrial ones still command high prices.
That is a very good looking area. Have the rest of your garage pics elsewhere here?
bparksntx
Frisco, TX
Another small cabinet that I cleaned up. Missing one drawer but it will be a good cubby hole for a Plano box for small parts.
BEFORE
AFTER
