mossyoakglock
- Joined
- Jun 12, 2011
- Messages
- 34
I recently purchased a digital torque wrench with the main use being the degree/angle function.
I have a 2022 Silverado and more and more nuts/bolts require additional degrees once the initial torque is reached where my previous truck didn't have any. The u-bolts, tie-rod end, upper ball joint and sway bar end-link to name a few.
Some of them have a range that is provided while others have a specific degree required. For example, the u-bolts are torqued to 59 ft-lbs, backed off 180 degrees, torqued to 59 ft-lbs again and then the final pass is 120-140 degrees. When a degree range is given, what is the best practice? Go with the lower end at 120 degrees or the higher end of 140 degrees or somewhere in the middle, say 130 degrees?
Secondly, between a click-type torque wrench or split beam, is one better than the other when it comes to accuracy, keeping accuracy longer, etc?
