I am restoring an old pinball machine with steel legs. The legs are a length of 90 angle with a threaded plate at the bottom for a leveling foot. One I insert the foot and rotate it to the proper height I should be able to to tighten a nut from the top side of the plate to create a nut jam and lock the leveling foot in that position, correct? I was thinking I may need two nuts but my understanding is that the threaded plate will act as the second nut. The only reason I am unsure is because it is fixed in place.
If you really want to impress me and satisfy my curiosity and have the time of course, would you either explain or diagram the physics behind your answer. I think I understand the principle behind why/how a nut jam works but would love someone to lay it out in a simple way.
Thanks in advance,
Thanks in advance,
