Obstruction Wrenches
What style of obstruction wrenches do you prefer
  • S type
    Votes: 5 22.7%
  • C type
    Votes: 13 59.1%
  • others
    Votes: 4 18.2%
  • Total voters
    22
zbadass28
PA
I like both. Use the "S" type for door hinges and the "C" type for intakes. I use them for other things to.
plewlandsbob
Elgin , Scotland
Need an option for, all the above! I have both and use whatever works for getting the job done. Sometimes you just have to take a cheap wrench and modify it to work.
RECox286
South Joisey (yeah, that is part of the USA)
Depends on the situation. I bend wrenches when necessary, and have
a couple of oem bent wrenches as well in both styles. Sometimes, you
just gotta do, what you gotta do. This poll is pretty much a bust as far
as it goes. There is really no reason to prefer one over the other, as far
as I am concerned.
Uncle Bob
shoturtle
Frankfurt AM
Can't seem to find a s wrench that is made in taiwan, all the ones I have seen are made in India, not something I would buy.
But there are c types made in Taiwan. So I might add a set of those.
2mJps
north central Mo
I have 1 c wrench 1/2 9/16 that i got because a lot of guys said you needed to take starter of off JDs with but you can use a socket on it easyer so i never use it. I also have a set of sae s wrenches but i have never found were they were needed. I have 2 metric wrenches i bent years ago. I keep a lot of cheap wrenches to mod if i need to. I have worked on every thing cars,pickups, trucks,cranes,forklifts, dozers,I will never sell my tools and will by more but their are things that i have got that are not very usefull.
bcradio
New Mexico
The gearwrench ones I have are made in Taiwan I believe
NUTTSGT
Northern Central Ohio
voted others..
went and got a set of the HF combos,
and have a torch set to make something if I need it.
Hmmmm, are HF ratchet wrenches all steel or is there plastic in them ? Anybody thinking what I'm thinking? A racheting obstruction wrench.
Damn, already being made. :sad:
shoturtle
Frankfurt AM
The hf ones are made in India. Gw has the ratcheting set on both c and s type. Do not need them that often so i can not justified the much higher cost.
