sparky 1971
I have several different styles of filter wrenches. Some filters are easy to get a wrench on, some not so much. I changed over to K&N filters. They have either a 1" or a 17mm nut on the end.
One I would like to recommend, Hazet # 2172. Pricey, but there`s cheaper copys out there...
Ko-ken Low-profile Oil Filter Housing Socket by ChrisCas aka Superautobacs, on Flickr
home use you will probably fine with plastic type cups, long as you don't over tight them.
shop use get a metal version, some filters are so tight that plastic type will expend or slip.
Fun Fact: Mahle specs. 20 N-m of torque for the OC-54 filter...
also, I can't believe nobody posted a pic of an old screwdriver being jammed into a filter
Was Just about to post a pic of a #3 Phillips. LOLalso, I can't believe nobody posted a pic of an old screwdriver being jammed into a filter
