Do any of you guys ever use 3 in 1 oil to lube your ratchets or just white lithium grease?
A altec876 Well-known member Joined Dec 28, 2011 Messages 76 Location MI. May 27, 2013 #1 Do any of you guys ever use 3 in 1 oil to lube your ratchets or just white lithium grease?
F Farmall450 Well-known member Joined Dec 23, 2011 Messages 13,371 Location Marengo, Illinois May 27, 2013 #2 White lithium grease, occasional WD40 if I happen to be cleaning it to blast crud out, then grease again.
K KoJo Well-known member Joined May 22, 2013 Messages 132 May 27, 2013 #3 Depending on the ratchet but I use sil-glyde in my Mac ratchets.
A allinon72 Well-known member Joined Jul 5, 2010 Messages 3,307 Location Indianapolis May 27, 2013 #4 I use Liquid Wrench lubricating oil.
V vssjim ALLIANCE MEMBER Joined Aug 5, 2007 Messages 2,713 Location McLean Va. May 27, 2013 #5 I'd rather use oil over grease as white lithium isn't all that tough any way.
C cmandp Well-known member Joined Dec 22, 2011 Messages 1,285 Location New Jersey May 27, 2013 #6 I use Superlube or Lubriplate primarily.
D d.mcfarland Well-known member Joined Jun 18, 2012 Messages 6,581 Location Western PA May 27, 2013 #7 I have a random bottle of lubricating oil with teflon in it that works excellent. It smoothed out a 3/8 Duralast and that's tough to do!
T TJx Well-known member Joined Mar 30, 2013 Messages 73 Location Northern KY May 27, 2013 #8 A mix of Tetra gun oil and grease.
OP A altec876 Well-known member Joined Dec 28, 2011 Messages 76 Location MI. May 27, 2013 #9 Thanks for the responses I'll give them a try. Just seams like I always have sum 3 in 1 on the bench and quick to use.
M Mr.Nutcase Well-known member Joined Apr 23, 2009 Messages 3,850 Location USA May 27, 2013 #10 depends on what type of ratchet Snap On recommend ATF for the old f730 series for the dual 80 superlube. Matco 88 recommends mystery oil(air tool oil)
A Applesauce Well-known member Joined Mar 12, 2013 Messages 273 Location Canada, eh May 27, 2013 #11 I've used Motorex green with good results, but switched not too long ago to Phil's Tenacious Oil, and then switched again to high-speed bearing grease. Not sure yet, but I think I liked the Phil's best.
S SMKS Well-known member Joined Feb 14, 2010 Messages 5,832 Location USA, planet Earth May 27, 2013 #12 Depends on the ratchet. Newer fine tooth ratchets often don't do well with grease, they're better with a light oil. Older course tooth ratchets can often handle grease. I have Superlube to use in those.
