Ok, what is this?
Jason280
I picked this up with some blacksmithing tools, any ideas?
pugsl
side
Old horseshoe hole maker, Just a wild *** guess have no idea. Just saw double pins no idea.
XJSuperman
Central Iowa
Am I the only one who just sees a blank thread? No pics, no links, nothing, and yet there are two answers like they see something there.
BonzoHansen
Looks that way. I see everything
MrSurly
East Texas
Unless the anvil of it has two holes , I don't think it's a hole punch. I'm thinking a harness-maker's tool, something for shaping, maybe joining/soldering thin pieces of silver or brass sheet or wire to make straps or buckles.
In other words, I have NO idea what that is.
rlitman
Long Island
Leather punches do not have holes on the anvil (only metal punches need that), so it makes sense that the anvil would be flat. To me, it appears that the round anvil is just big enough to cover any possible point that the twin punches could come down on, assuming the twin punches can be rotated.
J
Jason280
The pins aren't very far apart, and are maybe 1/8" each in diameter....and they slide through the tool when squeezed all the way together. The "leaf" on the rear pushes them both back out...
MrSurly
East Texas
With this latest detail I say we are looking at a chain making tool
What does the underside of that bottom die look like?
Or maybe an eyelet or small grommet setter?
SeisMec
Beryl, Utah
I'm curious as to the purpose of the recess in the anvil.
The anvil doesn't seem to match the pins.
I'm guessing you're missing other anvils and pins.
Silly question, didn’t see it above, what’s the name or wording in the pivot area?
J
Jason280
Didn't notice the writing before, apparently it's some sort of button setting tool...
rockettgpw
Sunshine Coast Qld down under
My WAG is this tool is for holding a pressed in button to keep ya fingers clear of the press. Think of the Levis jeans fly buttons. The recess on the anvil holds one side of the button, the fingers hold the other side and the press works between them. Just guessing
