old 134a bottles
dirtbikedude
i have a bunch of used up 134a bottles. I look at these things and think that there must be something i could do with these. i Know technically i am supposed to dispose of them.... but making something out of them would be more fun IMO. any ideas?...
rsanter
visalia ca
Pressure feed sand blaster.
Portable air tank
Tere used to be a kit that would turn the older R12 tanks into portable air tanks
Bob
Bruce Amacker
Cleveland, Ohio
I think later tanks had a one way check valve in the top to prevent re-use. Verify there is one by trying to blow into it with a rubber tip air gun to fill it- I bet you can't....
nine4gmc
Dallas
don't forget about the bull art :lol:
mikefiveseven
Hi all
I need 20 old 134A gas bottles 12kg+
I will gladly give £5 per bottle and collect them within London.
If it's outside the M25 I wouldn't want to buy them as fuel costs would come into play.
If your willing to help get in touch thanks.
I also need a couple of 15kg blew gas bottles for my heaters if you are looking to get rid.
SteveH-CO
Southern Colorado
Make a gearbox filler device.
I put a dip tube in one, filled it with 90 wt. gear oil, and then apply < 20psi to the tank. I added a long hose and a ball valve. I can set up the tank on the garage floor, climb under the truck, and fill the transmission and transfer case (and diffs) like a pro.
I wrote '20 PSI Max' on the top of the tank with a paint pen, to remind myself not to apply shop air to this device. That could make a big mess.
koditten
Midland, Michigan
Send them to me.
I got a lady who owns an antique shop. She has this one sitting out front.
She claims she could have sold it 30 times over. I'm tasked with welding up a bunch.
bonneyman
Desert SW
Ditto. If you can find older tanks before the check valves, maybe.
I did find an older can partially filled and - when I used up the R22 - kept the tank for some other project. Went to remove the stock valve on top to put something more user-friendly in it's place, but ended up screwing up the tank. Dang it.:sad:
