old garage to move or tear apart
chubscustoms
ok so up the road from my mother in law is an old 10x20ish (i didnt have a tape) single car garage. I spoke with the owner today and he explained he was gonna push it over and burn it but if i wanted it i could have it...soooo the million dollar question is has anyone done this and whats the best way to attack this monster it has a tin roof over some shingles then boards and has wood siding on it
onewaydave
Down the road from Dorothy and Toto
Yes it can be done and probably not too difficult. But is it worth it? Jacking and loading on a trailer is the easy part. Getting the trailer in there and the loaded trailer where you want the shed might be more difficult, depending on surrounding structures.
Dave.
C
chubscustoms
im thinking take it apart trash the old **** shingles and keep the wall and roof together in sections i have a big **** trailer
Dale B
Rowland Hts , SoCal
I've seen guys back a flat bed truck into the garage , lift the building with house jacks on the truck bed then support the building with scaffolding and drive the garage to the new site. You could even stack pallets up to support it.
Slaman37
North Florida
How far are you planning to move it? It is possible to move it in tact. like others have said using some kind of bracing underneath etc...
If you are going very far you should look into getting it permitted by that I mean oversize load permits anything over 8'6" wide and anything over 13'6" tall is considered oversized.
A local tow truck company may have the needed equipment and permits to move it safely.
Brad54
They make pre-fab sheds that are 12x24... they come in on a trailer. ANY shed company will be able to move that.
Plan B is to take it apart board-by-board, replace what's rotten, and rebuild on your property.
That's a LOT of work, and will take some time, but it's certainly not beyond the means of most people. If you want the building, free comes with a price.
-Brad
Stuart in MN
Minneapolis
When I built my garage, I had a company haul away the old single car garage that was in the way. They jacked it up, bolted in some 2x12s crossways to the side walls at about four feet above grade, backed in a truck, and then set the garage down on the truck bed and drove away. It was pretty quick and simple.
1948
IL WI border
i would take it apart. i mean, it will save you loads of materials. youll need to reroof it tho as stated. also if its old, it might be oak or some other dark wood, now they are made of soft pine.
atotalnincompoop
thunder bay
before i built my last garage i had to remove the old one that was there, similar to the size of the one your considering, i put an ad on kijiji and sold it for $1 with the condition that they move it, a bunch of guys showed up, dismantled it and loaded it on a flatbed. done!:3gears:
kbs2244
I like your take it apart to save the good stuff and burn the trash idea.
It will give you a lot more flexibility at the new building and avoid any possibility of needing permits for oversized load and wire lifting.
