Old Genie: no lights on either sensor
Rodango
Atlanta
I am going to check voltage at both sensors - I think that cleaning around the door when I replaced lift cables and springs I might have broken a wire or connection. There is no light at either sensor. It's an early 90's Genie system. The sensors worked until today when I worked on it. The wires appear very old and probably fragile. Do you know how and what for to check terminals (at the operator) on the Genie? Am I looking for AC or DC low voltage current?
The model is Genie IS550 /A. I have just downloaded the manual and will check it and the wires more carefully tomorrow.
Thanks
1redTA
Pace FL
Ive had the same issue, the copper gets real brittle with age. Mine uses telephone cable
kbs2244
if it works with the remote just get another remote and put where the push button is now
