Old hammers need handles
John Timmins
Flagler Beach, FL
I have 3 hammer heads that need handles. Two came from my grandparents shed; the other my friend found. I think I have found handles that might need an little bit of sanding to fit and wedge although I don't know if they will be the correct length. Two are ball peen and one is a claw I believe the claw could be 80-100 years old. It is small. I will post pictures
When I research are hammer heads are they described by weight or are they also categorized by size ? Or were there no standards....just what the manufacturer made for specific use like for shoe repair or small woodworking like picture frame making ?
Are the eyes for the handle standard ? The two ball peen are oval and the claw hammer is rectangular.
The claw hammer says Philadelphia Tool Company in a cursive font. It is 3 1/2 inches long.
The larger ball peen ( 12-16 oz. ?) says True Temper and I think there's a 2 under that with others stuff I can't read.
The small ball peen (maybe 8 oz. ?) has no writing. I believe it could have come from a car tool kit. My dad said early cars came with some tools.
Davefr
OR
Based on my experience, there are no standards when it comes to hammer sockets. You just need to find a handle end that's at least as big as the socket and fine tune the fit. A belt sander works well.
I'd try and get the length and profile as close as you can.
Unfortunately it's getting real hard to find good quality wood handles in B&M these days. I think Ace H/W is about the only source left.
I buy old stock hickory wood handles when ever I see them at g-sales.
J
John Timmins
Flagler Beach, FL
Here are some pictures
J
John Timmins
Flagler Beach, FL
Thanks for that web site. I have not found out much about the Philadelphia Tool Company. It was bought out by Plumb.- year unknown. I believe that claw hammer head is about 100 years old.
driftpin
Drill some holes in that stump remaining in the claw hammer before you look for a replacement handle. Since the handle inserts from the bottom, drive it-out from the top. Put it across the jaws of your bench vise, and use a 1/2" socket extension to drive it out with a baby sledge.
J
John Timmins
Flagler Beach, FL
The ball peen heads have holes which pretty much fit the new handles I ordered. After some gentle sanding and fitting, maybe some filing, I will get them together with a wedge.
The claw hammer handle has a rectangular end that can shaped to fit but the handle is too fat and long. I might return it and get another small oval end like the ball peen handles but I will have to epoxy the void around the end of the handle and the steel .
what is good epoxy for hammer handles ?
gungatim
west mich
I just use JB weld. tap in a wedge and fill any voids then wire it off. I've never had real good luck just using wedges alone, i'm sure it's an art but I find if I put epoxy on the handle, put it on wedge it, then fill it up, the head never moves again.
PS. I have, in the past, made handles from firewood fairly successfully, but recently had an epiphany when I saw a bunch of used baseball bats at a yard sale for 25cents apiece. they were beat up, chips out of them, etc. but awesome hard wood (Ash?)
now I make handles for the dozen sledge hammer heads and miscellaneous ball peins that seem to constantly multiply in my shop out of used baseball bats. it helps if you have a bandsaw and decent spokeshave but even if you just square it up and hand sand it to shape they make really strong handles for peanuts...
6PTsocket
Knowing the weight of the heads, google. ** oz. Ball peen hammer or ** oz claw hammer and see what the specs are for similar ones. There is no standard but at least you will get a feel for what the length typically is for that size head. Then you can do whatever suits you
tibwd
Newly handled hammers , sledges, axes, hatchets and the like are a pleasure to use, since you have resurrected them from the scrap heap. If you have a fire going, easy way to rid the hammer head of a broken handle stub= throw it in the fire, it burns out wihout any effort.....Plenty of how to vids on utube for hanging a new handle, also using glue or not, and treating the handle with boiled linseed oil (blo) good luck - Tom
