Old machininst tool? Please help identify
Black300zx
Elkton, Md
Hey all!
Years ago when my maternal grandfather passed, I inherited his tool box (he was a tool & die maker IIRC). The box was packed with endmills, gauge blocks, calipers, and other normal machinist tools, including this one which I have absolutely no clue what it is, or what it's used for.
Any help here would be appreciated!
Old Man Roger
Palm Coast Florida
Looks like it’s designed to set the cutting tool at a desired angle, pretty cool.
After a little googling, it looks like it’s called a rocker tool post. Can be used to eliminate shimming to get the tip of the cutting tool where you want it.
Maui
Upstate NY
It's a lantern tool post for a metal lathe. The tool bit would go through the slot and be held down by tightening the the screw with the handle on top. The semi-circular piece of metal in the bottom is called a rocker, and allows you to adjust the height and angle of the tool bit relative to the work piece.
joel63
Central FL
Here's the whole set up.
