Old oil device
Matthew3901
Maryland
So I see these from time to time in post on this forum. So what is the history behind them and general uses?
384424518175786861
1982fxr
Phoenix
Oil cans? They still make them but aerosol cans have put a beating on them. I grew up with them. Especially useful on equipment with chains.
royesses
The Eagle oil pump cans? They were the best made at the time. When we were building racing model airplanes(late 1950's) the eagle pumps were the only ones capable of filling up the bladder tanks we used. No drips, no leaks and good pressure.
Roy
Matthew3901
Maryland
So you would use them for general lubrication. Would you have several with different grades of oil?
1982fxr
Phoenix
Yes that was pretty common. Also may have several different ones with the same oil depending on where you had to get it into. Some old farm shops still have dozens of them scattered around. People still use them.
royesses
Back when I was building engines I used them to squirt oil in the cylinders, on the rings and pistons on the the main and rod bearings, etc. Also on the old hydraulic lifters to pump them up before doing the initial valve adjustment. Many many uses for them. Now I have goldenrod pump cans which are pretty good. It was good to have cans with different oils in them too.
Roy
ecotec
I have one for Kroil, drilling and tapping fluid, aluminum tap, cutting oil, 3 in one oil, honing solution...
ecotec
Here are some of mine. I try to only buy them if they are in very good shape and very cheap and still have a vintage label.
rhandwor
I've used a new one with brake fluid and a rubber hose for brake bleeding.
M_George
Eastern Pa.
I have one that I keep filled with old used motor oil. I use it as a stain for hot steel after forging. Gives the steel a nice black color and helps prevent rust.
ecotec
Drool......
Thank you... I appreciate it when people see the beauty in the stuff I like.
I probably have $10-15 into those 5.
I have very strict rules about buying them, because I see them so often. Like I said earlier in the thread, the condition has to be amazing and the price should be $3 or less. I would pay more $5-10 for a second Kroiler in as good or better condition.
I have a Goldenrod one, like FoxRacing showed earlier in the thread. It is the only one in my collection that I regret. It is a nice made in USA pump oiler. The design is better than the vintage ones, in that it is much more stable (the wide bottom is ideal). For the money I spent on it, I could have bought 3 beautiful vintage ones.
I label most with vintage 1/2" and 3/8" label makers.
ecotec
Has anyone tried Permatex 81950 in a pump oiler? I am thinking about trying it.
6PTsocket
I am amazed you can find Dymotape that still has adhesive that has not dried out. I have a couple of those labelers that I have not used for years. I long ago switched to P touch but I am a hoarder and have a few old tools for long gone stuff.
ambenz
NW Chicago Suburbs
I have a few old machine tools that use metal bushing instead of sealed bearings.
They have little reservoir you have to keep filled with oil using these little oil cans.
If you look in the picture above, you can see the hinged cap covers for the reservoir where the bushings are enclosed in the base housing...
I just use 10W30 motor oil for most of my machine tool applications.
ecotec
You can find 3 packs of the 3/8" Dymo tape in the electrical department of some Lowe's. It is the 1/2" Dymo tape that you have to find at estate sales.
