Old Reznor Heater
chevydriver37
Buffalo, NY
Hi all,
Not sure if there's any old timer HVAC guys in here, but I have a Reznor Unit Heater, Model US-75-F Heater for my shop. Input/Hr is 75,000 and Output/Hr is 60,000 BTU. 115v motor & 105 Watts. Serial # is BK6N5799.
I was probably made when natural gas was first disovered :)
This is all the info off the model plate inside the unit.
Motor died, and I ain't got no heat!
Does anyone know if there's any replacement parts out there for this old bone shaker? I checked rezspec.com, and a few other places, but I didn't see any cross reference to anything.
The motor is a Wagner, 1/40th HP, 1000 rpm, type TM. Other numbers on the motor were FR43T, and R349A2516, 1 phase, 115v, 1.5A.
Any help or advice is really appreciated!
Thanks
Rick
arb905
try to find a motor repair company in your area. they can get you a replacement or fab a mount for a new motor.
arb905
I had a repair shop I used to use regulalry. They could find a replacement motor for just about anything. If they couldn't find it, they would build a mount for a newer style motor.
arb905
the FR43T is the frame size for the motor, this is what most places look for when sizing replacements.
rickairmedic
louisville ,Ky
Chevy driver if you have a Johnstone supply in your area you might just pull the motor and take it to them and see if they can match it up to a newer one .
Rick
cowboyjosh
Call Reznor, they surprisingly have a stash of parts for obsolete units. Also have you tried reznorparts.com? If neither helps, I also recommend finding a local motor shop that could rebuild your existing or fabricate a new motor.
C
chevydriver37
Buffalo, NY
I'll give reznor a call. Also checked reznorparts.com, and they don't even list a US-75. I found tnb.com, and they listed a US75 and it's newer replacement model UDAP. Sent them an email to see if they can help me out. Thanks for pointing me in the right direction...
trythis
st louis
I have an ancient fan motor from an old heater that I tossed because it needed too much work and parts were unavailable. The motor is built like a tank, solid cast steel frame attached to 3/16 thick steel cage. I plan to use it for a venting fan later, I think it might be explosion proof. It wasn't a Reznor though.
My heat exchanger was cracked and as old as your is, it probably is too. It may just be a lot safer to get a new heater to prevent CO poisoning.
cowboyjosh
Not a bad idea; unit heaters I understand are allot like traditional furnaces, they have their lifespans. Allot of times screwing around trying to find parts to fit old **** is better spent installing a spanking new unit, or even a slightly used unit found on Craigslist or a scratch and dent from a dealer or distributor.
bluetick
HTML:
Real good advice by last two posters. I have replaced many reznors lately due to cracked heat exchangers. Not worth sinking money into a new motor if you don't know the condition of the heat exchanger. Better to go with new...not even used, cause a used one might also have a cracked heat exchanger!
