Old tool find..
joelw23
Anyone interested in these.. I have no use for them.
LXCam
The die on the bottom is an excellent unit. I've had one for years. I'll try to remember to grab the manufacturers name off it tomorrow. Funny part is I use it a lot. I don't remember it being a Imperial, but it could be.
LXCam
Good timing since I'm in the shop. Mine is a imperial. It's every bit as nice as the 37.5 degree ratcheting rigid I bought a couple years ago. And like yours I'm missing the actual flaring thing-a-bobby. Does anyone know the technical term for both pieces cause obviously I sure as heck don't. :)
e_d
Oregon
Is the atkins tool available? Can I see another picture of it?
thank you- Eli
ttpete said:
All that's needed are the double flare buttons that are missing from that one.
very few of the earlier consumer-marketed flaring tool sets came with the double-flaring buttons. almost all of them were just the two pieces.
no need to double-flare copper tubing to fix your oil furnace line or a water line in the house - they used SAE 45° flare or compression fittings.
double-flare sets were a specialty item.
so... that set there is most likely "complete" - just as when it was new.
