I asked about a vintage jack a while ago and one of my friends picked it up and delivered it for me today.
Weaver. 51.5" long, 5.5" saddle. Likely a 2 ton.
Unfortunately description by seller was wrong - bought it unseen. Was told that all wheels work, jack needs some oil and is stuck...
Well - it's rust frozen except for handle. With a little bit of rubber mallet I started moving the pedal and released the lock handle (which probably needs to lock on a half-circular piece at the bottom which probably moves up...
Discovered that the cover from label till rear wheel is missing. Emailed the PO today - may be I get lucky? (doubt it though...) The last picture here shows some corrosion on the rod going into hydraulic unit. I hope it can be cleaned up without machining (it probably goes against rubber seals which might cause problems if not tight).
It was left in the dirt somewhere - some rust on the bottom, one of the springs is broken and there is another very corroded, there is another part on the bottom which will need replacement, the bolt on the left part of image 9 is moving freely...
Well: tons of negatives...
Positive: I could not find another picture of this jack on the internet.
I am out 40$ as of now
How bad did I do?
E-mailed Castle Equipment Co for jack diagram...
I never restored a jack in my life and never tried to fix anything that complex which is rusted solid.
Any advise would be appreciated (including what would you spray it with when attempting disassembly - I think WD40 would not work and evaporust would be too expensive for the size)! PB Blast?
The work is busy, but I will start slowly working on it as time permits using all the advises.
...I wonder how much it would cost to professionally rebuild this hydralulic unit?
Does anybody by any chance have a similar complete or parts jack? If it's a parts one, do you have a cover? If complete, can you make pictures of it? In case I succeed with the restoration and make it work, I assume that somebody can create a new part for me - it's a bent plate with the designers detail at the bottom - I hope it would not cost me an arm and a leg to have a machine shop make a reproduction...
All ideas will be greatly appreciated. I am well over my head with this one...
How bad did I do?
