Old work boxes' tabs
Bob Smell
Dayton, Ohio
Does anyone know, where to get replacement tabs, for old work electrical boxes? I've found, that if I take the tab off, and put white grease on the screw, and tab, they are easier to tighten up.
b-boy
Buffalo NY
My guess is that because they are so cheap, there's no market for spare parts. I'd just replace the whole box. You could also buy some boxes and try to see if the tabs fit your older boxes.
CJ7VFR
Central New Jersey
A single gang, old work box, costs $3.35, at Home Depot.
Versus paying .25 cents for a new tab, and $4.95 to ship it to you, for a total of $5.20 if they actually sold those things separately. Your better, and cheaper off, buying a new box with the tabs, because even driving around trying to look for the tabs will costs more than $3.35 in gas.
I don't think I have ever had much success with those old work boxes with the flippy tabs.
I have been using the metal old work boxes with the "Battleship" metal folding tabs. Those seem to be a lot better to work with.
Jim
Crazyjake8493
Upstate NY
I've never seen spare tabs, just get a new box for a couple dollars.
Don't bother with grease, just take your drill or impact and run the screws in and back out of the tabs. Then when you put them in the wall they're easier to tighten.
CJ7VFR
Central New Jersey
Even if you wanted to grease them for some reaaon, why would you need to remove the tab to do so and why would that necessitate a replacement?
I have come across a few that when tightening them up, the flippy tab does not quite flip to the proper spot it was supposed to flip to, and because you can't see it, you have no idea if it actually flipped all the way into the correct position.
Then, because it is not getting tight enough you put more force on the screw going into the tab and then you hear that dreaded "snap" as the tab cracks at the screw location. Then your hosed because you have to remove the box and replace it.
That is why I stopped using them, and went with the metal boxes with the Battleship tabs.
Jim
rburke65
Canfield, Ohio
I never use those plastic boxes with the plastic tabs because they are cheaply made and the tabs break off. I only use metal old work and the "Hold its" or what ever trade name you are used to. And, as far as that goes, you could the Hold its for this very situation.
CJ7VFR
Central New Jersey
The "Hold its" for the boxes are another name for the Battleship tabs that I am talking about. I learned to call them that because if you turn one on its side it looks like a battleship. They work for just about any type of box, metal or plastic. I use them on metal boxes for the strength of the box.
Jim
njride
Ive heard battleships and madison bars around here. Never have heard hold its. They work good so long as you use them right.
For the originql question, just replace the box, if the hole is too big and your on a stud, smartboxes are a good quick fix.
cmandp
New Jersey
Eh my house is full of those old metal boxes. I've been using the plastic boxes to replace them because they are a pain. The metal boxes I have are small making it hard to get the wire in them and clamped and it's easy to get cut.
They make the old work plastic boxes in a "heavy duty" version made out of fiber reinforced plastic that are a lot sturdier. I would suggest trying those out if the regular ones are giving you trouble.
jakeo25
I cannot believe most of the answers are about buying a new box. This is not our first rodeo, folks. Yes, We can do our own search for new boxes and can add shipping costs. If ANY of you have done electrical repair work, some gorilla used a power drill to tighten the flippers and you have buckets FULL of old work boxes that you pirated -- or you just tossed them in a landfill. If the drywall is in reasonable shape, the replacement of these flippers is MUCH easier than pulling the box and redoing all the wiring. Nothing in NEC code prevents you from doing this, and saves your customer money.
mike93lx
Richmond, VA
Your first post is to complain about recommendations in a 3+ year old post?
Welcome!
Jim greengo
Behind my house
Jim
When in doubt I just run the screws out as far as I can before installing the box,then run them in by hand with a screw driver so you can tell if something isnt working.
Cut in boxes are the only time I use blue boxes for anything,I use the tan allied brand boxes for anything I nail to a stud.
Jim greengo
Behind my house
Plaster ears.
Zeke
The best part is when he said, "If ANY of you have done electrical repair work..."
I posted earlier in the thread but now that its back I thought of an idea. Grab a small piece of 16 or 18 ga. metal and cut a tab a little long. Start a barrel with your needle nose and then finish by wrapping it around a plastic screw anchor. Squeeze it just enough with your 9's (maybe add a touch of CA glue) and viola, new tab. You could put a 90º fold on he edge for a real pro job.
There, you've only spent 10 minutes fixing a 2 dollar part. ;) 🔨
nadogail
Coronado, CA
When the cost of the labor to reuse an old box exceeds the price Of a new box l don’t see a cost reduction.
Crazyjake8493
Upstate NY
I don't mind the plastic blue boxes but I take my impact and quickly run the screws in and out on each tab before installing the box. Makes for a much easier time once the box is in the wall.
JRC3
Southwestern OH
I have a bunch of blue tabs in my box if you want them. I typically buy the metal tabbed boxes.
Just go buy some old fashion F clips.
