Oliver 232D Table saw vs Sawstop
Grant Gunderson
Bellingham, WA
I’m in the market for a new table saw. Been looking at getting a sawstop but a friend of a friend offered to sell me an Oliver 232d. Seems in decent enough shape but it would require me also purchasing a phase converter. Seems like a well built piece of old iron, but how precise are these old beasts? Thoughts?
seber
Deep East Tx.
The Oliver was a very heavy and precise machine but you should be aware of the tilt mechanism. The blade it stationary and the table tilts. That makes angled cuts a nightmare as the work either wants to slide away from the fence or close up the cut and bind.
G
Grant Gunderson
Bellingham, WA
Thats great info. Thanks! I dont see my self doing too many belved cuts, but its nice to know the issues. The bigger issue is I can pick up a used SawStop contractor saw for 4-500 more... so debating the cost benefits of the older saw vs a newer one. The safety features of the Sawstop are nice, but not a major selling point for me.
ozyborn
I will take an older well built tank like that Oliver over a Sawstop any day.
rlitman
Long Island
The Saw Stop saws I'm familiar with are all made like tanks. Now if you were comparing against a plastic contractor saw, that would be a different story.
nic6paul
The table does not tilt on this model. The saw arbor tilts. I own one. I believe it is the model 32 that the table tilts.
G
Grant Gunderson
Bellingham, WA
Looked at the saw today. Its pretty damn impressive. However the blade takes FOREVER to come to a stop. Any ideas on how difficult it would be to install a brake on this thing?
CJCar
South Central PA
If you do a VFD for your phase converter, it will include breaking (ramp up / ramp down speeds).
rsanter
visalia ca
Yes you can program a VFD for ramp up and ramp down time/speed.
That’s can be a good thing to do.
Please keep in mind that this will also put more heat into the VFD which must then go somewhere.
Keep this in mind and you may want to increase the enclosure size for the VFD espocallymif you will be turning it on and off a bunch
Marctrees
TX/LA border - Toledo Bend
Photo of saw and asking price?
Don't forget you will want to spend approx $500 for a good fence system.. similar to the original Biesemeyer.
THEN you will have a SAW !!
But still, for 99% it is wiser to get the SS, or as said old Unisaw, PM or comparable.
Marc
Marctrees
In a production shop doing repetetive cuts the blade wind down time is less of an issue.
In a home shop, or small one two man shop.. the blade stop time is much more of a hassle AND big safety hazard.
If you CAN stop it in sub 5 seconds with the VFD or whatever.. ONLY then would I seriously consider it.
Marc
Marctrees
Also.. It is 12" blade capacity ?
Most of the older cab saws w 10" have max depth cut of like 2 7/8" or so.
You need to check if in fact this one DOES cut deeper.... other wise the only advantage is it's massiveness.
Just some things to consider.. but still asking price and condition ?
Marc
Marctrees
It is possible it will take a 14" blade, but not be able to fully lower below table.
But more depth of cut then.
I don't know the above, but it WAS the case w SOME saws labeled as "12" back then.
Marc
u3b3rg33k
Marc
sawstop stops the blade RIGHT QUICK i hear :)
otherwise for convenience a VFD + braking resistor wouldn't hurt one bit. still fails the hot dog test.
Cooter Brown
I'd love to have a saw like that Oliver. Makes my old PM66 look like a toy.
If you go to vintagemachinery.org you can download the manual for it.
Marctrees
man - Do you have anything else helpful to say ?
It advises the OP of a FACT that he should look into.
I'm just giving him a heads up to avoid surprise.
Thank YOU for going out of your way to help the OP.your kind help in this thread.
:beer:
Marc
Marctrees
No bull! 7 posts in a row?
All pertinent info OP may or may not know.
Your previous post was in fact VERY good succinct info.
But OP was asking about the Oliver.
So, in case he was getting the hots for it ready to get it I figured he needed to check out a few very key points.
So sorry if I typed too many words for you.
Marc
Cooter Brown
Other things for OP to consider--are the original micrometer fence, quadrant and miter gauge included with the saw?
Marctrees
Yup.
Only thing is.. for larger panel work a 52" Bies style fence may be better I would think.
And, I don't think anyway. the Bies setup would preclude usage of the original fence if desired.. not sure though.
Marc
Cooter Brown
Marc
A t-square fence like the Beismeyer would be much better for panel work. I think you could still use the regular micrometer fence with it. The quadrant is of course a specialized tool, and the miter gauge is not standard--the slot is much bigger than most.
The miter gauge, fence and quadrant can bring as much by themselves the saw without them will.
