peter2772000
Or happy ones?
My CH twin-cylinder supposed 6hp (*rolls eyes*) 60 gallon purchased at Costco in the late 90's is getting tired. Rated at 10 CFM @ 90 psi but can't keep up with my 3/8" air drill which needs 9 CFM. As well, I've noticed that it takes longer than usual to get back up to 120 psi than before.
To be honest, I'd be an idiot to replace/fix it. Other than my sandblaster which only sees occasional work, the low output isn't really an issue. But I never claimed to be the sharpest knife in the drawer........
I've priced out a set of rings/gasket kit and a valve plate, comes out to +/- $200 CAN shipped. And that includes only one crank ball-bearing ***., the other one is no longer available. I can get a new compressor from my supplier for $330 CAN. It's an Omega model CK-32, which replaces the CK-30 but is identical. As a bonus, it provides 12.5 CFM @ 90 psi with the same motor I already have.
Any experiences with Omega? Canadian manufacturer, but this is the first I've heard of them.
http://omegacompressors.com/download/catalogues/OMEGA PROFESSIONAL_CONTRACTOR_BROCHURE_EN.pdf
Page 7, the unit that uses the CK-30 compressor pump is the PP-6060V, compressor specs are just next to the unit specs.
