SickSpeedMonte
We just moved in to our new place and I started working on the shop. It started as a pole barn and had a garage added to the end of it where a sliding door was. The sliding door was removed and a wall was framed up. Both spaces were insulated and sheathed with corrugated steel. I want to create a pass-through for vehicles to get to the barn side. (There is another sliding door still on the other side of the barn that was also framed over to make the barn into a climate controlled gym, but no driveway and soft ground over there)
I found today that the barn side has trusses and the garage has rafters. The ridge beam for the garage is supported by the last truss. There is also a beam running directly below the ridge beam on the ceiling that supports it. Below that ceiling beam, there is a pieced together post of sorts made of two 2x6's. They are not continuous as one breaks at the girts and the other breaks at the fire break. I think it would have mad a lot more sense to put a 6x6 here instead, going all the way to the ridge. There are also a lot of girts on the garage (green) side. I'm curious if these were added to support that broken up center post. It seems like an afterthought.
The garage is deep, so if I can remove one of the original posts that I believe was for the sliding door, I could still have enough width to turn a car into the barn side. I would leave at least one wall stud beyond the central load-bearing post, as they are tied together with a short 2x12 at the top.
Am I missing anything? Any advice? Should I do anything to shore up that center post?
