Opinions for garage layout
Jeepster04
Getting close to pouring concrete for my garage... Soon as the weather dries up enough to get more gravel and concrete trucks to the garage....
Someday Ill 'hopefully' have a two post lift and I want to make two 6' square pads that are 6" thick for anchoring the lift to. Obviously I need to know where to put those pads before the pour is made. The rest of the pad will be 4".
Its tough planning things since they hardly ever work out like you think. Someday we will have a house with an attached two car garage for the DD's. The current garage will always have two vehicles sitting in it that are only driven on nice days. A third may always be in there but it would be nice to be able to park the DD's in there till a house is built someday. The rectangles represent our biggest vehicle. Ill most likely never have a truck, just dont need/want it.
The back center of the garage will have cabinets/tool boxes/ for whatever width will fit. There will also be a door that leads to the other half of the pole barn (not concreted, used for a barn). That width is currently 12'. The depth from the two post lift to the back wall is 13'.
Anyway, thoughts?
  • Spacings.pdf
pcmeiners
Find a large parking lot which has little use on a Sunday (school), bring a whole bunch of small 2x4 blocks and a chalk line, layout you garage to scale, including vehicles, tool boxes, machinery, storage rooms, bathrooms etc. Walk around your completed scaled chalk garage to insure clearances.
J
Jeepster04
Seems like a pretty good idea. Instead of a parking lot I may just try it inside of the garage :). I didnt mention it but its already built.
Wasnt sure if anyone might have a similar situation and always thinks 'shouldve done it this way.' Maybe someone with a 16' wide garage door and a 2 post lift.
Look at all of those scrap 2x4's!
astroracer
Mid_Michigan
To get a hoist in there, line up the inside of one post with one side of the door. that will offset it so you can squeeze a car in beside the lift.
Set the hoist back far enough so, with a car all the way up, you can open the garage door all the way.
With the hoist in there you will not get a car lengthwise, behind it. Maybe crosswise. If you put the car on skates you can move it easier.
Mark
Boxes, cabinets and benches will probably end up on the side walls. That back wall is going to be taken up with cars if you can stuff them in there. The side walls will be much more accessible.
HoosierBuddy
Southern Indiana
I did exactly what you are trying to do when I built my garage.
I don't think you can do it without knowing what lift you are going to buy. My suggestion would be to beg/borrow/steal enough to put the lift in NOW rather than sometime down the road. The lift you choose will have instructions on the footprint required and you can plan accordingly.
If you can't do that, then I would not worry about doing anything. The lifts I looked at specified a minimum of 4-inches concrete, and although I went 6 under my posts, that's overkill. The big issue I had was where to put my PEX for heating and not run an anchor bolt through it.
Anyway...you're spending a bunch anyway....just spend a bit more and get what you really want.
Phil
astroracer
Mid_Michigan
Like Phil said, you do not need 6" of concrete for the lift. Way overkill and just ads cost for no real benefit.
I just posted this in another thread. BendPak should know what is required. :)
Just for shits and giggles I copied this from BendPaks site.
Depending on the lift, they don't start recommending 5" of concrete until you get upwards of 35K on some of them. others go up to 8" but that's more then most of us need to lift.
Lift owners and end users are responsible for the safe installation of their lift. The figures below represent suggested concrete specifications, but should not be construed as actual requirements for your building, facility or application. Because local and statewide building codes may change and / or vary, always check with the building architect before installation for additional guidance on UBC compliance requirements. In no event shall BendPak Inc. be liable for special, consequential or incidental damages for the misinterpretation of this information. BendPak Inc. reserves the right to make changes to this document without incurring any obligation to notify the public that changes were made.
4-POST LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
HD-9ST-B
9,000-lb. Capacity / Four Post Lift / Narrow Width
3-1/2" Min. Thickness / 2,500 psi
HD-9-B
9,000-lb. Capacity / Four Post Lift / Standard Width
HD-9STX-B
HD-9XW-B
HD-14SS
14,000-lb. Capacity / Space Saver
4" Min. Thickness / 2,500 psi
HD-14
14,000-lb. Capacity / Extended
HD-14X
14,000-lb. Capacity / Extended / Limo Style
HD-14STL
14,000-lb. Capacity Tall Lift / Space Saver / 82" Rise
HD-14ETL
14,000-lb. Capacity Tall Lift / Extended / 82" Rise
HD-18
18,000-lb. Capacity / Standard
HD-27
27,000-lb. Capacity / Standard
HD-27X
27,000-lb. Capacity / Extended
HD-35
35,000-lb. Capacity / Standard
5" Min. Thickness / 2,500 psi
HD-35X
35,000-lb. Capacity / Extended
HD-40
40,000-lb. Capacity / Standard
HD-40X
40,000-lb. Capacity / Extended
HD-14LS
14,000-lb. Capacity / Alignment
HD-14LSX
14,000-lb. Capacity / Alignment / Extended
HD-14LSXE
14,000-lb. Capacity / Alignment / Limo Extended
HDO-14LSX
14,000-lb. Capacity / Alignment / Extended / Open Front
HD-18A
18,000-lb. Capacity / Alignment
HD-27A
27,000-lb. Capacity / Standard / Alignment
HD-27XA
27,000-lb. Capacity / Extended / Alignment
HD-35A
35,000-lb. Capacity / Alignment
HD-35XA
35,000-lb. Capacity / Extended / Alignment
XR-12AE
12,000-lb. Capacity / Scissors Alignment
2-POST LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
XPR-9F
9,000-lb. Capacity / Floorplate / Chain-Over / Narrow
4" Min. Thickness / 3,000 psi
XPR-9FX
9,000-lb. Capacity / Floorplate / Chain-Over / Wide
XPR-9FD
9,000-lb. Capacity / Floorplate / Direct-Drive / Narrow
XPR-9FDX
9,000-lb. Capacity / Floorplate / Direct-Drive / Wide
XPR-12FD
12,000-lb. Capacity / Floorplate / Direct-Drive
6" Min. Thickness / 3,000 psi
XPR-10C
10,000-lb. Capacity / Clearfloor / Narrow
XPR-10CX
10,000-lb. Capacity / Clearfloor / Wide
XPR-10AC
10,000-lb. Capacity / Asymmetric Clearfloor / Narrow
XPR-10ACX
10,000-lb. Capacity / Asymmetric Clearfloor / Wide
XPR-12C
12,000-lb. Capacity / Clearfloor / Triple-Telescope Arms
XPR-15C
15,000-lb. Capacity / Clearfloor / Standard Arms
XPR-18C
18,000-lb. Capacity / Clearfloor / Standard Arms
8" Min. Thickness / 3,000 psi
SCISSOR LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
XR-12AE
12,000-lb. Capacity / Scissors / Alignment / Extended
SP-7X
7,000-lb. Capacity / Scissors / Full-Rise Platform Style
SPECIALTY LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
PL-6SP / PL-6000
6,000-lb. Capacity Single Post Parking Lift / Deck
PL-6SPX / PL-6000X
6,000-lb. Capacity Single Post Parking Lift / Deck / Extended Rise
PL-7 / PL-7000
7,000-lb. Capacity / Two-Post Parking Lift / Deck / Standard Rise
PL-7X / PL-7000X
7,000-lb. Capacity / Two-Post Parking Lift / Deck / Extended Rise
LR-60 / LR-6000
6,000-lb. Capacity / Low-Rise Lift
LR-60P / LR-6000P
6,000-lb. Capacity / Low-Rise Lift / Portable
MD-6XP
6,000-lb. Capacity / Mid-Rise / Frame Lift / Portable
P-6 / P-6000
6,000-lb. Capacity / Low-Rise Lift / Pit-Style
P-6F/ P-6000F
6,000-lb. Capacity / Low-Rise Lift / Pit-Style / Flush Mount
J
Jeepster04
Here is another drawing with the lift 1.5' past the door opening. I always pull into the garage with my passenger side mirror ALMOST touching the door opening (gives most room to open doors between vehicles), so I have the vehicles sitting 0.5' from the edge of the door opening. With the lift positioned like this you can pull straight into the bay/lift.
The door is 10' tall so this would allow, depending on the length of a vehicle, enough room to open the door without hitting the top of the vehicle.
Im getting a bendpack XPR-9DS.... Ive been figuring 'wide configuration' since I will mostly be lifting suv's. Someone mentioned 13' from the back wall works best so thats what Im currently using.
Like this my cabinets and such could go on the right wall with the point of view being standing in the garage door looking in.
  • Spacings2.pdf
