Opinions needed!!!
frankjd513
Hey All,
I recently purchased a home and am looking to get the vibe of my garage up to my standard. When you first enter the garage from the house immediately to your left behind the door for about ten feet in there are a few systems....Home water filtration, AC, pressure regulators, ice machine etc etc and id like to cover it up but still make it accessible. Anyone ran into this before? As the title says im open to opinions! Thank you 20240819_111415.jpg
AC-WC
NE, Indiana
Honestly I don't think I would do much. I see a water softener that needs filled at least 1x mo, The ice maker depends on how much you really use it. Regular freezer access daily/weekly. If you put up wall/doors you're always opening and closing when you need to access. You could do a sliding curtain but I don't think you would like that (I wouldn't).
nadogail
Coronado, CA
Opinions are like **** Openings; everybody has one and most of them stink.
It’s your garage and your call, no matter what you decide there will be those who agree with you and those who don’t.
After deciding on a plan of action you will retain the privilege of changing your mind and priorities.
IMHO, when you make a decision you are opening yourself to criticism and the world is overpopulated with self appointed critics who have never stood in your shoes or shared your problems.
Theronswanson
Maybe some sort of privacy curtain like they have at hospitals/ doctors offices. Simple track at the top, move it when you like, doesn't restrict air flow of the mini split etc.
F
frankjd513
Curtain is eh, not something as see through or flimsy as mesh but maybe some type of panel with dots/holes/slots to let the ac and heat disperse with some type of door to access but also have it not be such an eye soar
Debcrow
New Mexico
You have come to the wrong place...
I have never seen anyone on GJ have an OPINION.....
If you seal it off it is going to need ventilation because those are heat generating items. If you seal it up well it will probably require forced ventilation. Is there some specific reason you want them out of site in a garage?
racecougar
Missouri
Adding a wall or curtains is just going to consume more space and reduce air flow to the items that need it (mini-split and ice machine).
Copymutt
Colorado
If aesthetics are the concern go w/ expanded metal or chain link w/ movable panels. Paint what color works.
NUTTSGT
Northern Central Ohio
I was going to suggest louvered closet doors but it will require some framework for the openings.
However, the placement of the mini split kind of ruins that thought. Putting it beside the ice machine wasn't a very smart idea.
Curious about the reason for a full size commercial style ice machine in a residence ??
Stuart in MN
Minneapolis
The mini-split is over the water softener/ice machine. That wont work.
Is there any slack in the lines connecting the mini split head unit to the condensing unit outside? Maybe it can be relocated to one side or the other without any major modifications.
F
frankjd513
I just moved in the previous owner had that ice machine. It is a big overkill IMO. Found some metal privacy panels that will seem to do the trick!
