24oc joist are already up
Sent from my SM-G930R4 using Tapatalk
I hung 7/16" OSB 24" OC in my garage. I wouldn't do it again as I'd use metal like I did in the house garage.
This. Especially in our climate OSB does not fare well from what I have seen/experienced.
For the inquiring mind, what are the differences in cost between metal and OSB?
In my area I can get painted metal for about $1/sq foot. 7/16 OSB runs about $10 for a 4x8 sheet (about a third).
I've got about 4,000 sq feet to cover and am trying to balance off the costs of painting, ease of handling etc.
Where are you located? $1/sq ft for metal is pretty high based on what I've been finding. Metal is usually about 36" wide, and ordered by length, so it seems like I typically see the metal priced by the linear foot rather than sqft. Make sure you know what you're pricing so that you can compare accurately.
For reference, I ran some numbers a couple of days ago and got $0.60-0.75/sqft for metal (16ft lengths)
If you'd be leaving the OSB bare, then it's going to be a fair bit cheaper than metal. But if you're planning on painting it, then the costs/time to do that work start to make metal more appealing. 4000 sqft is a lot of ceiling!
