Above 1200 Sq/FT Out on Quaker Road
J
jblnut
In the Middle of MN
Another "because you can" suggestion...push on the cheater pipe with the bucket of your skid steer, less chance of slipping off and coming into contact with your family jewels ;) 🤷‍♂️
Will a mini work :lol_hitti
Don't let the boss man see you lying down on the job, you might jeopardize that raise! :lol_hitti
To get a raise you gotta get a paycheck first :lol:
J
jblnut
In the Middle of MN
The 2nd garden sprinkler has been installed !! Now to run the water and power lines to it before Mother Nature puts a hard shell over the earth.
Mama Bear and I got the opportunity to go to a resort this coming winter and she couldn’t say no to that. I’m also fairly excited as we’re going with some people I can tolerate quite well lol.
I was cruising Marketplace a while back and found a guy that built fire rings out of some large roller chain. I had him build us one and I’m pretty excited to make a fire in it !! At 500lbs no one will be walking away with it any time soon lol.
Sunday the little dude and I went and cleaned up a round bale that I damaged when baling. What mess lol
Wood Mountain doesn’t look all that big until you stand a small human or two in front of it. Should be enough BTU’s on that pile to get through to April. I’m thinking I’ll fire the boiler up this week or next. It’s supposed to get down into the low 20’s over the weekend and Mama Bear is asking when she can have warm feet in the house again. So it’s time I suppose lol
J
jblnut
In the Middle of MN
What kind of permits do you need for a pivot there? I know here you have to apply for a water taking permit, which once granted can be amended if low water advisories are declared.
No building permit of any kind. Just the annual pumping permit from the DNR. The permit we have is for a certain number of inches of water per acre per year. We’re allowed to go over as much as needed as long as the usage is reasonable and we can justify it.
Also, wtf did that roller chain come off of?? That's some big chain!
It’s a chain from an oil pumping unit that held up a 30 ton counter weight to balance the weight of the oil and rods and pumping stuff. Or so I was told.
That fire pit is rad!
I saw it and messaged the guy immediately. It was $450 so not a small spend for a tightwad like me but I’ll put it in the “repairs” area and list it as “roller chain” when I do my taxes 😆
When spare links are needed, your great grandchildren are never going to find them :)
Right !!
J
jblnut
In the Middle of MN
Do you guys have flow meters on the irrigation wells then?
Marti
Nope. The number we report is calculated by the irrigator panels attached to the well based on run time and the flow we measured when the well was test pumped for 24 and then 48hrs. I think it pumps right at 450gpm when it finds its spot after pumping for around an hour. It pumps close to 600gmp at first until the water level drops in the pipe.
J
jblnut
In the Middle of MN
That ********* tree root is fairly waterlogged. Huh.
Oh hey it’s not a tree root !! It’s actually a 12” sleeve we had put under a road so we can run an irrigation line to the other side and use the same well for two irrigators. Gotta get the chunk of sleeve out and shove the pip through !!
Pops slobbering wire lube on as I wrangle it in. There is a seam at the midpoint that it kept getting hung up on but we got it in after a bit of fighting. We were both absolutely shot after shoving 90’ of 6” pipe and an 1-1/4” wire assembly through this sleeve.
Hey there it is !! What a relief to se it out the other side. I discovered my mud boots are no longer waterproof so that was fun.
Hell yeah !! Well side riser is in place finally.
Line is finally up to the center. Hell yeah !!
Some dummy drove over a rock sideways while turning and the track popped off. A little ratchet strap work and it’s back on. I can’t believe it worked as well as it did to pull the track back on.
Mama Bear and I trekked to the big city to attend a MN Wild game. It has a crazy ending in overtime and was a decent time. She got seats 4 rows up and didn’t tell me what they cost when I asked and I’m okay with that lol.
A few hundred bucks each for hockey seats is okay because I spend money on things like this that were a bit more than a few hundred bucks lol. A complete hydraulic crimping setup with fittings and hose coming to a farm shop near me.
Boostingaz
Indiana
👍 Being able to make your hoses will be so nice! It's always the crimp that fails that seems to be the worst part about all the store bought ones.
I've had good luck with Hydraulics Direct's ultra flex 5583 psi hoses. They are pretty nice. The nicest thing is having a swivel on one side.
J
jblnut
In the Middle of MN
A buddy purchased a crimper and we used it for the first time a few days back to make a new hose for my skiddy quicktach that had an extra hole in it.
Having received zero instruction on how to use it we dove in head first. An experienced eye can spot at least a few things we’re doing wrong here lol
First one we made the connector wasn’t in the die far enough. 2nd one made a shark fin deal. We have the entire die setup in upside down. Oops. It took both of us to get it all to fit together so we could crimp it. That didn’t seem right lol. Now we know :lol_hitti
jollygreengiant
Ontario, Canada
And that's why there's no teacher quite like experience lol.
I'm surprised your basically rink side tickets were only a few hundred each. They are usually around $1000 up here.
J
jblnut
In the Middle of MN
Agreed. I learn by doing and this was an inexpensive lesson so far.
I honestly don’t know what they cost. I doubt they were $1000. Mama is usually fairly frugal but hockey makes her lose her mind so 🤷‍♂️ I know the seats we had were someone’s season ticket seats as the people we were sitting between chatted us up about if we knew whomever the regulars were. I told the one guy “you don’t recognize me?” and laughed a bit and he said “no I don’t, who are you ?” I told him and he said “never heard of you” I says “That’s how I like to keep it, rather low key. Nice to meet you!!”
J
jblnut
In the Middle of MN
My wood stove door had a rusted hole in the front and they warrantied it. Sweet deal !! The original door was mild steel, new one is 409SS like the rest of the stove. Gotta swap the hardware over and get it installed before firing up the stove.
Leo helped me untwist a bunch of chains so we could clean and sharpen them.
Wash em up and let em dry before sharpening.
Fired up the wood stove !! Mama Bear was grumbling that her feet were cold. Well okay I guess we’ll fire up the stove lol
Pops remembered he had a semi trailer tarp in a shed so we tossed that on the camper as well as the camper tarp deal I bought for last year.
We ran a few things through the shop to make sure everything that needed attention got it before winter storage. The baler had a few things that needed attention and we got it all tuned up and ready for next year.
One of the super important things was to line up all my fork things :lol_hitti
J
jblnut
In the Middle of MN
Did you say "fork it" when done? 😁
After a good day of forking around what else is there to say other that "Fork it!!" when done :lol_hitti
If I didn't know any better I'd think you were trying to attain @Strouty like levels of forklift utility lol.
:lol_hitti
That lawnmower of yours sure does come in handy.
Coming up on 150hrs on it already. I like it quite a bit but wished I'd have went up to a 3r right away. I already went to this from a 1r thinking it'd be excessive but it shows it's petite size when doing loader things. A 3r is build more like an actual tractor than a lawnmower. The next one will be a 3046r or whatever they have in 4-5yrs.
J
jblnut
In the Middle of MN
Creating this post as an Affiliate link spot for me (and others if you'd like) to support GJ. Not sure if they all work but I'll update it and change things around as needed. Huh. Only spAmazon got tagged ........
J
jblnut
In the Middle of MN
Before it was cold and snowy we got after a few barn projects. Like replacing a few lights that were burnt out. I sure do like this new forklift. It’s way more capable off pavement.
I had an audience watching me swap these goofy crosseyed plugs over to the new lights.
An IBC tote makes a great man basket !! We replaced a few cables that help hold up the gates and tightened up all the gate hinges. There are 60 hinges in total lol. It took a while.
I replaced a UVC-G3-PRO with a G6-Bullet as the G3 decided to only work in black and white for some reason. The AI detection stuff with the new G5 and G6’s is pretty cool. The G6 will read license plates for quite a distance somehow and it’s dead nuts accurate.
If he comes when you call his name and lets you play with him and give him scratches I think that makes him a pet ….. he’s gonna be the tastiest pet we’ve ever had :lol_hitti
J
jblnut
In the Middle of MN
Picture your happy place. This is one of mine. I love sharpening chains for some reason. Maybe because I know it means I am gonna do chainsaw things again soon or just because it is sort of no brain auto pilot work once the jig is set properly. Don’t know. Either way watching the sparks fly and the dull chain stack shrink makes me smile.
I finally took the time to mount the chainsaw on a stick to something so it could actually be used. Pretty stoked about this thing.
I was so excited to use it that I took zero pictures of it in use. Here is one of Pops cleaning up some brush I cut with it. I can’t believe how well it works !! Soooooooo much safer than standing in a bucket to cut branches off. Tons faster as well.
A fun looking couple of pallets showed up the other day :lol2:
I took things out of boxes and Leo put them away. Pretty slick shelf/drawer setup.
Hello hydraulic hose making setup !! I’ve wanted one of these for a loooooong time and finally pulled the trigger.
After our hard work we rewarded ourselves with a movie night. Pirates of the Caribbean #1. Hell yeah.
J
jblnut
In the Middle of MN
Holy smokes, that's quite a collection of Erector sets!
I have made A LOT of hydraulic hoses in my lifetime, definitely would be a game changer to have all the stuff at home!
It's just the one. The others are Lego boxes and a few other things.
I'm excited to make a few hoses that are weeping but haven't failed yet !!
You will love having that hydraulic setup at home. Those stupid hoses always fail at the worst possible time when the hydraulic shops are closed.
That's the biggest reason for the purchase. It was close to $8500 for everything so it wasn't done lightly but it'll come back in less hassle and gives me one less reason to leave the property lol
What is that chainsaw on a stick powered by? Hydraulics I assume?
I make chainsaw noises in the cab and it spins. The louder I make chainsaw noises the faster it cuts. Gotta be careful though. I sneezed and the chain went so fast it flew off !!
J
jblnut
In the Middle of MN
Takes all the fun of robbing a 10' hose and zip tie it up to fix a leaking 2' :LOL:
There is a certain amount of fun and adventure to be had by finding adapters and enough zip ties to make an improper hose work and keep it out of the way !!
very important to do thorough walk around before using a piece of equipment ... doesn't take long to empty the hydraulic reservoir when hose is missing/free flowing :LOL:
No kidding. A system pumping 40gpm with 15gal in the tank doesn’t take long at all !
Mike, that's a perfect description of my life.
When I “retired” in April 2022 I wanted to spend at least a week without stepping foot off the property and I got dang close. I don’t think I’ve made it more than 6 days in a row without leaving. I aim to break that record this winter somehow.
I like it here. A warm shop to work in, barns to keep the critters happy, a warm house to keep the humans happy and a wood stove outside to power it all. What else could a guy want !? I mean really.
Bob Heine
Boca Raton, Florida
If you’d ask me I’d tell you I like rum. My supply cabinet tells another story lol
Mike, in my drinking days I was lover of Scotch and Liane favored Rum, especially Bacardi Black. My attraction to Scotch might have had something to do with the frugal Whisky rather than the wastrel Whiskey on the label. In 1996, we took a two week drive in England and Scotland, including my bucket list tasting tour of the Whisky Trail. Best stop was the Edradour Distillery near Pitlochry, which was the smallest in Scotland back then (lots of small craft distilleries have sprung up since). Had my last drink almost 23 years ago but didn't have the courage to throw out anything in the liquor cabinet. In addition to the thick layer of dust on everything, the plastic bottle of Popov vodka has imploded a bit. I also feel like my not needing a drink shouldn't stop a visitor from having one.
Actually, the Popov vodka was a special purchase for a friend who only drank Smirnoff vodka and hated the taste of any other brand. When I finished off the Smirnoff one morning I decided to refill it with the cheapest stuff I could find. Served a ****** Mary and later a Screwdriver to my friend, pouring the vodka from my "Smirnoff" bottle and was truly surprised she gagged it down without a word. I can easily believe a whisky drinker who takes it neat or with an ice cube or two can tell the difference between top and bottom tier stuff (especially the single malts). But I have a hard time believing a Taquila drinker can tell the difference between a Margarita made with Patrón from one made with Los Cabos Silver. The salt on the rim might be an easier test -- is it Himalayan or Fleur de Sel? -- with the color being a hint. My guess would have been Morton Kosher regardless because that's what's in the bucket next to our stove.
Jim_No_Garage
Millington NJ
Reading the phrase "Popov Vodka" above just gave me flashbacks to the University of Delaware in 83/84. Vodka and Hawaiian Punch "layer" drinks. You took a glass and poured in a slug of vodka. Lay a bandanna over the glass and touched it to the vodka in the center, pour in the Hawaiian punch slowly and it would sit as a separate layer on top of the vodka. For some reason we called them "machines". Don't ask me why . . . We did similar thinks with Ronrico run and coke I believe.
Tales of a mis-spent youth!
Jim
