overhead door size
navajo123
Bend, Oregon
I'm building a 32'x36' shop that I'll be using for working on cars and some woodworking. I'm considering garage door size. It's my first shop and not sure what is practical. I'm leaning toward an 8' door and a 12' door both 10' wide. Any input would be appreciated. Thanks
kbs2244
I went with 10 wide by 10 high.
The extra height was so a truck or van with ladders on top would fit.
A 12 foot high would be nice.
cjcocn
Manitoba, Canada
I went 9' high by 11' wide.
The height was to accommodate my lifted '92, while the width was to make it easier to get in and out with (for example) a car hauler (if I ever have to put it in the shop for some work).
gnpenning
I have more questions than answers.
Those are great sizes. Go with high lift tracks or follow the roof line tracks if you can and get the doors out of your way. If you plan to put a hoist in or just to keep from hitting the doors when moving wood around when the doors are open. With high lifts you will need jackshaft openers.
I like to put in as wide as door as I can. You will love it backing in the dark and rain. For trucks and SUV's don't go under 10' wide 12' is even better for single width. If you do decide to change and go with double width don't go under 18' wide, 20' is even better.
The biggest thing is make sure whatever you have now or you plan to buy will fit with room to spare. Over sized is a good thing. You don't have to always raise it all the way up
Hurricanoday
Kitsap County, WA
I took everyone's advice on here on my 40x60, went with a 18x10, 10x10 10x10 and 12x12. While I'm sure the big doors will be nice, you will be paying and the doors are big... This is going to be my only garage for a while so I probably won't have doors for a bit and the doors will be more "commercial" looking because they are probably gonna be commercial doors
rburke65
Canfield, Ohio
Years ago I built a 32' x40'....increments of 8' ......and I just had a barn type sliding door which was 10'x8'. I could get my Chevy in and out ....ok....but the side mirrors were close. When I built my retirement shop, I went with a 12'x8' garage doors.....LOVE the extra 2' width. So much nicer.
GTFiero
30x60' Pole building. Mostly car work and storage. 12' walls. Did a 10'x10' insulated panel door for car shop and a 18'x10' tall non insulated for the storage side. Really like them.
andgott
Athens, TN
I put a 10'h x 14'w... Go as big as you can, I don't think anyone has ever wished they had a smaller opening.
TractorJeff
Elkhorn, WI
Got to be at least tall enough to get the Kenworth, Mack or Peterbuilt in!
Why?
Because you may buy an RV and with age, you'll hate trying to get it in or out.
In my case we had to take the duals and half the cab off from a Combine once to get it in to do some engine work!
kbs2244
"With high lifts you will need jackshaft openers. "
Isn't this why the sell extender kits for the rail type openers?
On my 10 foot high I have a rail type from CL that was on a 12 foot high.
I had to cut 2 feet off the rail to make it fit between the door and ridge.
(Rails follow the slope.)
Bu it works fine.
FANTM58
Brighton, Co
I'm planning my 40x60 , and I'm gonna break ground soon
I'm planning on 2 - 18x10`s on the 60' side
It may be overkill, but I won't be shifting car around to get
Them in or out...
larry_g
oregon
Have you put some thought into whether to put the door (s) on the gable wall or the side wall. Being in snow country you don't want snow sliding off the roof and blocking the door. Welcome to the forum.
lg
no neat sig line
MrBalll
West Texas
I went with an 18 wide and 10 high with a high track kit. Absolutely love it.
If you go with two doors I think you have good sizes picked out. It would irk my OCD having a slim and wide door, but it's what you're needing it for that determines your size.
gnpenning
Bu it works fine.
Not clear about your terminology???
Pictures would be helpful.
finn
The UP, God's country
I've got a 12'w x14'h and a 14'w x14'h in my shop, and 2x 10' w x 8'h and a 14'w x 10'h in the garage by the house. Another garage has a conventional 17'w x7'h door.
Go at least 12' high, unless you have (or plan to have) a fifth wheel or motor home, in which case 14' is mandatory.
10' width is the minimum I'd consider, although that's really too narrow to back an rv or car trailer into. 14' width seems ideal to me because it leaves some wall space on the entry wall for water and air hose reels.
Anything wider than 14' reeks of residential two car attached garage.
7' high doors are problematic with a pickup and cargo in the bed.
willf650
I went 18'x11'h for the main door and a 10'x10' rear to pull though.
For just vehicles 10x10 would be my minimum.
I could of fit it I would have preferred a 14' tall door.
BDT/NWMN
Erskine, Mn
For cars and woodworking; why would there be a need for a 12' high door?
The first thing to consider will be the largest vehicle that will go through that door.
If you have a need for a 12' high door, go at least that wide, or wider, for a more balanced appearance.
If planning for a car lift, the reason for a 12' or taller ceiling exists, but the door can still be sized for the vehicles that will pass through it.
I put a 16' wide X 14' high door on my shop because I needed the height for working on semi trucks. 18' wide would have been better yet, but I put that 16' wide door on a 28' gable end that also includes a walk-in door. I wanted to retain the remainder of the 28' as shear wall.
Wider makes it easier to maneuver a large vehicle, or multiple vehicles using the same door.. But the extra height will be of no value unless it is actually needed..
The expense of having multiple doors vs a single, wider door with one set of tracks and one opener may be worth doing some pencil work on..
Door tracks can go straight up the wall to the ceiling, rather than cobble up the overhead space in a stall that is a common complaint on standard garage door tracks.
Larry G mentioned about having doors on the eave side of a garage. I had a new 26' x 28' car attached garage build that way in 1976.. The best thing I ever did to that garage was tear it down, add 30' of footings and slab, and built the new one with the door on the gable end like I described.The roof line was changed from north-south to east-west. I wanted to keep the overhead door facing the east.. The damn thing is: I wanted to build it that way back in 1976, but to 36' x 36' dimensions. The house would have been turned a quarter turn also.. The knowledge of the elders pleaded that it would look goofy from the road, and the house would be hidden by the garage... I fixed that when I planted enough trees to isolate that blasted dusty gravel road from the house anyway.
The original 26' x 28' garage footings, which I reused, were footings, 4' wall, and slab all poured separately.. I regret not using the same method when adding the 30' slab with footings. That 18" of concrete wall is better suited for dealing with snow runoff from vehicles and washing the floor. My original floor was sloped toward the overhead doors; in addition to having a floor drain.. When I poured the new floor, the entire 28' x 56' length was poured level. The reason for this being level was because I wanted a perfectly level floor for working on large projects that need a "level" surface.. I do have heat tubing in the floor, but during the winter months, the snow melt from the vehicles can make a mess. So, if Your plan is to have the floor sloped toward the overhead doors; You would likely desire to have all the overhead doors on the same wall.. Having doors on more than one wall would require having the adjacent floor sloped toward that door!! On a 32' x 36' shop like you are planning, that could be a challenge. When it comes to current building codes pertaining to floor drains and floor slopes in a garage, best to review your local building codes before getting too far with the planning.
I mentioned a few things I would never do again; polexican23 and Tractor Jeff mentioned their short-comings with too low and too narrow of doors.. Our goof-ups are all ready spoken for, so whatever You do; don't copy our goof-ups:willy_nil
metschers
Billings, Missouri
My shop 36x48 12 sidewall, I went with a 8x8 in the front next to the walk thru door, a 10x10 on the east side, and a 10x16 on the back wall. All doors insulated with Liftmaster 8500 openers. When all open in good weather, I get a great breeze.
