Oxygen Sensor Thread Chaser
Ohmthis
Outside of Louisville KY
I have a Lisle brand thread chaser, it does what it claims to do. Kroil is what I use for penetrating oil. It hasn't let me down. I've heard that 50/50 trans fluid and acetone is awesome. I've been meaning to try it, but the kroil always works.
plinker
Northern Wi
+1 on the Lisle, antisieze before use though. PB blaster, Kroil, CRC freeze-off & power lube all work good.
mbshop
visalia ca
I just got a tap for the ones I had to deal with. If your o2 sensor does not have a ground wire, be carefull of using antisieze.
dogdog
I have good luck with both brands... if I have to choose I would get the Lisle one just because it is driven by a socket instead of a hex. ..
***NVM both can be driven by socket.... so choose either one is fine.
Personally I have a set of large metric tap/die that covers it and that thread repair tools.
Andy22882
DeMotte, IN, USA
+1 on this. I am a professional mechanic and have found many times that a thread chaser won't do the job, it would be good to have both.
