PA Garage
Mayor
Eastern, PA
I really got some good ideas from this site so I wanted to post some pictures of my own project. I still need to do the floor. Thinking about a lift and some floor ideas.
wythors
Very impressive organization! Kinda fits with the BMW thing. I love the work bench area.
Nicely done and welcome to the site.
bje31
Western PA
Looks good!...neat and organized...also like the beige walls...di you run plastic for the air compressor line?...be careful with that set-up...if it ever bursts..OUCH...
M
Mayor
Eastern, PA
Thanks, I took a look at your garage and really like the set up. The floor looks great.
M
Mayor
Eastern, PA
The air lines are PEX tubes and should be ok. I know steel is the right way to go. I am thinking about switching over the summer.
Alistair
Herndon, VA
Looks good. Do you know what size the garage is (looks like 20x20 or close to it)? I'll be renovating my garage this summer, so I'm always looking for ideas for "normal" sized spaces.
stioc
SoCal
What kind and how many florescent lights are you using ? It looks well lit up even with the warmer color on the walls - which looks pretty cool IMO.
Very nice, I love it!
tp-otus
central pa.
Great looking garage, I love the way you organized it. I need to ask is that a electric heat unit on your ceiling. How does it do for you? Reason asking is I have a 220 unit with 5000 watt and it barely works with my 484 sq. ft garage. Keep up the good work :thumbup:
M
Mayor
Eastern, PA
Thanks everyone for the great comments. This site has some really great garages and ideas. My garage is 21wx21lx10h in size. I also have a shed (14wx16l) with an 8ft garage door for all the lawn stuff and overflow. If it was not for that shed I would be stuffed. The air lines are pex and should be ok but I will run some steel pipe this summer as per this site. As for the heater I need to run power to it so I really can't help with that type of question. The garage on the coldest days is around 50 with out heat. I did have that heater in a 40x20x8 garage at my last house and your right about how little it worked. The walls in that garage were brick. I should have the heater hooked up in a few weeks. One thing I do rember is the cost of running that little heater. Propane ventless might be the thing for me.
M
Mayor
Eastern, PA
The lights in the garage are two florescent 4 footers with daylight bulbs. Homedepot $45.0 per unit. The best I could get off the shelf. I can't rember the number but the bulbs are really small and bright. Not much help???
dboat
Dallas, Tx
Mayor,
Since your garage is so organized. Could I talk you into a trip over to Erie to help me get mine that organized too?
Dana
M
Mayor
Eastern, PA
Orefield is near Allentown, 5 miles north of the city. I was also in Harrisburg today again. On the way home I got stuck on route 78. Bad pile up today, they closed the road. Three hours of fun.
The Alchemist
Doylestown, PA
Nice setup.... i've spent the past month or so re-doing my wife's kitchen and this spring it's the garage's turn for a makeover. I primered the walls when we moved in, and now it's time to put a nice coat of paint on the walls and ceiling and to do something with the floor.
As you can see, I too have a 'deer' but I need some re-organization as well.
As you can see from my ceiling, I definitely need some more storage space for lawn equipment and my wife says I need a shed.... I'm figuring a 24x24 with 12 ft ceilings would work....lol
M
Mayor
Eastern, PA
24x24 is very big, that would be great. You will have so much room for new toys. Thats the problem, filling it. Every 5 to 6 years I build a new house. This is my 3rd. The next one will be my last. 4 car garage with two lifts. My little shed is so stuffed right now. The JD takes a lot of room up (9ft long with weights and bagger). A few weeks ago I was in the same boat your in. Just fyi I had the JD all ready for winter (detailed) but guy next store will not clean his leaves up. So I have to go out every few weeks and **** them up. His new craftsman tractor (26hp, wow) had to be fixed 4 times this year. The last time he had a fire under the hood and deck (he won't talk about it). Nothing against craftsman but the right tool for the job comes to mind. Well just wanted to get that off my chest.
I feel better now. Good luck with you project. :thumbup:
M
Mayor
Eastern, PA
Well, Guys a update is in order. As time goes on I am trying to hold my ground. Where does all the stuff come from? A few new things like a Snap On box and a fan. Have my heart set on a custom tile floor.
Also made some major adjustments in my shed. Let me know what you think.
boiler7904
NW IN
Great looking garage and shed.
Your color scheme is what I have in most of my house (SW Believable Buff walls with SW Extra White ceilings and trim) and was thinking of using in the garage but with slightly lighter walls.
How much land are you on? I'd love to be out in the country a little with some land and a small tractor.
M
Mayor
Eastern, PA
I like the color and most of my house also is in the same tones. It really hides the dirt well. As for the tractor it is a John Deere 2305 diesel. I have 2 acres but hate to use a shovel. Overkill for my needs right now but I have a plan.
M
Mayor
Eastern, PA
Well another update. Due to a basement project I have to move my small wood shop into the garage. This is hard to do and still keep the layout close to the first makeover. Plus like most of us I have to keep the cost low. Picked up a few more gear tracks and hooks. Still need to add more lights, outlets, and another workbench. I would like to get everything done in the next few weeks. Will post a few pictures in the next few days. :thumbup:
M
Mayor
Eastern, PA
I added two shelfs over the garage door. I must have 20 black crates so I wanted to use them. The shelf boards need to be extended but you get the idea. I love finding wasted space!
Pudmunkie
Can I make a suggestion for that corner?
My dad always kept a step stool / short short ladder around and easily accessible in the garage. This made it possible to mount our ladders up near the ceiling and out of the way. It seems to me that you could mount the ladder horizontal above the window and utilize that space for some shelving for the tanks and various bottles. The snow blower won't fit in the shed?
