Paint Can Shakers
finn
The UP, God's country
Anyone using the Astro Pneumatic paint can shaker in a home shop, ie non professional environment?
I wanted something for occasional use, but not badly enough to spring for a $489-3500, and up professional unit.
The Astro was $155 at Summit Racing, with free shipping.
That’s a little more than the HF at $149, but it’s worth the extra $6.00 to not have to drive to town.
Ok? Junk?? Super handy and durable???
My neighbor is a bodyman, so I suppose I could use his well seasoned professional shaker, but he works out of town four days a week, plus my shop is a mile from his, so it’s not exactly convenient.
Comments?
The Cobbler
I have the astro pneumatic one . I bought it off ebay not working due to bad seals. shout out to @Astro_Pneumatic_Tools for their great customer service and selling the repair parts.
It works as expected .
A lot of times I just use my home made stirrers/ mixers in a cordless drill
Junkman
Northeastern CT
Check with some small independent paint stores to see if they have a used one that they will sell. The paint companies give the machines to the stores for free based on sales, so when they get a new one, the old one gets relegated to the back room.
F
finn
I’m ok with spending $150 or thereabouts.
most automotive paint is sold through a couple of parts stores. Hardware stores and the Sherwun Williams store plus Walmart also sell paint.
I really don’t want to make a career of this. I live 12 miles from town, and try to stay away during tourist season. Spending two days chasing nickels isn’t going to happen, and I don’t need a pro shaker. Just something to mix maybe five gallons per year, max.
Of course my wife could use it, too, for paint and stain around the house.so there’s that.
whateg01
doo dah, kansas, usa
I've thought about those but would need one so rarely it's hardly worth the expense for me. Not that I've let that stop me in the past. For rattle cans I stick them in the lathe. I still don't really understand how spinning the can mixes the paint since it doesn't seem to rely on the ball. But it does seem to work. I wonder if it would work with gallon cans, but what a mess if the lid came off!
The Cobbler
I would have never bought the pneumatic shaker but it was cheep , and the parts were under $20 If I recall . I thought I would use it more than I do , and In all seriousness, to mix a few cans here & there, I would recommend a mixer in a cordless drill . no issues for storage, no set up issues, and doesn't take up a lot of space
dnschmidt
Phoenix, AZ
I have the ASTRO and it works fine. The only thing I will tell you about these types of paint shakers is that you must BOLT THEM TO A CONCRETE FLOOR if you're shaking gallon cans or even heavy quarts or they will walk all over the place. I use the 3/8" Simpson concrete screws going through a plywood subbase and that gets the job done. One thing they do great is shake up cans of shaving cream, and yes I really am lazy.
scooterbum46
South Central Michigan / ex Gulf Coast Florida
Those spray bomb sawsall kits are all over Amazon
The type Swsman shows is simple, no farting around with a sawzall. On the ones I've made, the base has a 3/8 bolt shank sticking out of the center, which you chuck in the drill. The tube is larger than the spray cans, which allows the can to go off center and really shakes it. 15 seconds right side up and another 15 seconds upside down to thoroughly shake a spray can.
Components are a plug of wood fit in the base of the 3" PVC pipe and a 4" 3/8" NC bolt threaded into the center hole in the plug. The hole is tapped - yes, threads in wood - the bolt threads are coated with CA glue and threaded in to the plug, then the bolt head is cut off. Ready to use! You can hear the ball racing around in the can once you've shook it for a few seconds.
I've never used a shaker for gallon or larger cans, I like a 4 blade stirrer used with a drill, it always seemed to me the shakers at the paint stores always introduce aeration into the paint.
alwaysFlOoReD
Airdrie, Alberta, Canada
I use the short 3" tube and a rag in the air paint shaker for the spray cans. But making one strictly for spray cans is a good idea. Next time I have 20 minutes I'm making one.
And my shaker is screwed into a 4x8x3/4" ply on sawhorses. Doesn't walk...
