paint, specifically ceiling paint...
tff
Greer, SC
My new garage is near completion and am planning for painting it inside... What do folks recommend for ceiling paint? Standard (flat) interior ceiling paint or something different? Thinking of painting the walls 'eggshell'. Thanks.
Stuart in MN
Minneapolis
I'd use regular flat or satin interior paint. Gloss will show every imperfection, if you have to wipe stuff off the ceiling you're doing something wrong. ;)
850xpeps
I’d gloss the garage. And flat ceiling paint a house. Dust and dirt will collect on the ceiling and need to be wiped off.
yeldogt
Having a little more durable finish is not a bad idea in a utility space -- an eggshell will give you the ability to wipe something off. I have about an eggshell in mine -- I mostly vacuum .. but occasionally you swat a bug and need to wipe it off.
Gloss is fine for walls when going for a drama -- like red and black. I did a space in white glass many years ago after being in a another space w/o much natural light -- too much glare. I find the better quality eggshell has the durability of the cheaper semi .. and its nicer.
Years ago when there was less choices -- most kitchens and baths got semi.
Bruce 993 SEA
La Conner, WA
New paints are much better for staying intact when wiping stains off. A lot has changed in the last 40 years of latex paint. Even the last 5 years have seen improvements.
Gloss will show imperfections as already stated. Go flat or satin.
K'ledgeBldr
Johns Creek, GA
"Show every imperfection"
It's a "garage" not the living room! I'd do gloss enamel- yeah, the oil-based kind. With that I "could" use a garage hose to clean/wash it.
Ray-CA
San Diego CA
We did a gloss exterior grade paint on the inside of our garage. In our experience, the exterior grade paint is more durable.
Ray
Git
S Cal
Never liked painting ceilings but recently did one. I saw that Lowes has a 'color changing' ceiling paint. It goes on with a purplish color and dries to white. Actually worked pretty well
And of course, keeping up with the latest trends, it is a primer and paint in one :)
Hpozzuoli
Rhode Island
My ceilings and walls are gloss. Run some diesels occasionally in the garage and being able to wipe everything down is priceless. Also like mentioned above, get the exterior formula.
T
tff
Greer, SC
That's a good idea!
Thanks for everyone's comments!
Jakemedic
Cornfields of SE Iowa
I have been using semigloss bright white for the last few houses. The shine looks cool. When I move again I will do the same thing. In my shop I used semigloss too, Did make for an easy way to wipe down the walls.
Bretny
Dutchess county NY
I think alot of people forget that on here. Its a garage and there actualy build a "garage".
roscoe2000
Seat Pleasant Md
For my garage, I went with a white semi-gloss. One I wanted a bright reflective surface to accent lighting and second surface that would help with repelling dust. As a added fiture, i can wipe and/or wash.
K'ledgeBldr
Johns Creek, GA
And of course, keeping up with the latest trends, it is a primer and paint in one...
What you meant to say is "latest marketing gimmick".
You do know the definition of "primer"- there's no way a "primer" can be "included" with a paint.
"Paint and Primer in one"- Greatest marketing ploy since sliced bread!
jetnow1
CT.
As I am closing in on Medicare I find that I need better lighting, so I used white semi gloss in walls and ceilings. Easy to clean when needed, and the light
reflects evenly when I am working. Did not matter as much when I was 30.
Stuart in MN
Minneapolis
I'm reminded of when I built my garage and I had a dispute with the roofer, who had done a crappy job. Partway through the argument he said, "it's just a garage". I reminded him that it wasn't just a garage, it was MY garage. I won the argument, and he re-did the roof.
The point being, maybe you wouldn't be bothered by seeing those imperfections in your garage, but maybe it would bother other people in their garage.
