TL;DR: I'm painting an airplane. I need help figuring which equipment and paint to buy, and some tips on technique.
I know this isn't the kind of thing that's normally posted here, but I've actually found more useful information on vehicle painting in this forum than anywhere else. What I'm painting is a lot like a car, it just... has wings. If nothing else, this could be very entertaining for you guys.
I have an airplane that needs painting. As in, there's missing paint all over it. It needs to be painted for corrosion resistance, but in the process I also want to make it look better. Most airplane owners are loaded and would just pay somebody $25k to do it for them, but that ain't me.
My standards aren't exactly high. I want the colors (white on top, red on bottom) to be solid and have a clean line between them. I need the paint to be smooth for aerodynamic purposes. Shiny would be a bonus. Showroom perfect is not necessary - anything would be an upgrade from what I have right now. Wet sanding between/after coats is not a problem.
I've never painted with a HVLP sprayer before, but do have a little experience touching up cars (read: rattle cans only). I'm very mechanically inclined and am usually pretty good at picking up new things like this quickly, so I'm hoping that will be the case here as well.
I've already purchased a 3M full-face respirator and appropriate filters. I've also got the yellow 3M masking tape and blue fine line tape, as well as tape with plastic already on it. I have a 26 gallon 5.5HP 9.9 CFM air compressor. I don't have the cash to spend on something bigger, but could purchase a receiver tank or something if needed.
I don't have a gun or any accessories. I keep reading that the Harbor Freight purple gun would be perfect for my needs and is more or less disposable, so that's what I'm considering. I'm doing my research, but haven't yet figured out exactly what else I need with it.
I also need some advice on what kind of auto paint to get - I want something simple that won't require a lot of extra coats or a more complicated process. Again, my standards aren't high, so simplicity beats something that will take a lot more work but only look 10% better. I'd love to be able to complete the process over the course of a few days, but I'm seeing a lot of things about not taking too long of a break between coats or between base and clear.
The biggest complication is that I can't move or disassemble the plane. So I'll be painting at all angles, including while underneath it with only about 18" of clearance. I've seen videos of people using the purple gun to spray upside down, but I haven't yet figured out how they're doing it.
I have removed any flaking or chipping paint, and sanded all the edges down to give it as smooth a base as possible. Stripping the plane is not an option, unfortunately. I've also primed all bare metal with a rattle can zinc phosphate primer to prevent corrosion (very important in aviation). It sanded down nice and smooth with some wet 2000-grit sandpaper.
Feel free to give me a hard time - I'm definitely taking on a big job and am not quite ready for it. But any helpful information you can give along with that ribbing would be greatly appreciated.
*For any of you who may be familiar with planes and FAA regulations about painting them: I am following all required rules & regulations while doing this. It's being done under the supervision of an A&P, and will be properly checked out & signed off. I've left out some of that information above for the sake of brevity & clarity.
