Painting Concrete Block Walls
04fivefour
Perry Township, OH
What is the best paint to use as a finish coat on concrete block? I'm looking for a very high gloss to be able wipe of grease easily. I have already coated it with white Drylock. Do i need to use a separate primer or is the Drylock enough? any input is greatly appreciated.
Bondo
Greenfield, Maine
Ayuh,.... Rustoleum industrial enamel,...
Roll out 2 coats, 'n it'll still be there when yer great grand children are old, 'n retired,.....:thumbup:
Grimpala
Use a block fill material first and you'll get a much smoother glossier wall finish.
With a good masonry primer like Drylock, you can use any kind of top coat. With a primer and 2 finish coats, you should get a pretty smooth surface,
Rustoleum industrial enamel is good stuff. Requires a catalyst or it would take days to dry.
04fivefour
Perry Township, OH
I'm trying to get a texture like my elementary school had. All the walls were block but they were really glossy and easy to clean. That could just be from them painting them every year. and having so many layers of paint.
Grimpala
I think drylock might have a filling property to it, im not sure.
Blockfill (generic term, a good painter/supply house will know what to suggest) is what they used in your elementary school. It fills the small voids and smooths the wall, it keeps the block from soaking up all the paint that you apply. It's a thick, thick primer.
04fivefour
Perry Township, OH
Thanks for the clarification. This is my first time ever having a block building. I started the drylock this morning and it was extremely thick and it looks to do what i was looking for. we will tell when all is said and done.
brownbagg
they make a block sealer, finisher paint, its like a first coat with small particle to fill the voids. I got couple five gallon buckets of it
