Painting OSB questions.
G-ManBart
That's good to know. Did you notice any additional problems with cell phone reception or radio interference?
That's a really good question. We are in a low signal strength area to start with, and even when I had just the exterior metal walls, I could barely get reception or data. After adding the interior panels I think it was slightly worse, but it was hard to tell....some days were better than others.
Ultimately, I bought a used cell booster for $100, put the reception antenna up near the peak of the roof and put the transmit antenna inside the shop. I already had wiring running through the attic over the shop that feeds a couple of outlets on the barn side, so I just ran a feed from one of the junction boxes and added an outlet in the attic (which I had plans to do anyway). Now I have no problem getting calls, and data is pretty decent as well (only 3G)....it's good enough.
NUTTSGT
Northern Central Ohio
I'll add this too, when using oil-based Kilz, make sure you have plenty of ventilation. The **** does stink and can give you a nice headache if you don't get some ventilation while painting.
visiting guest
buy the foil sided osb
and enjoy the most energy saving benefits.
white too offers a good Albedo factor
but silver foil would be best.
or buy elastomeric roof coating "gloss white" 5 gallons of coating 65.00
and roll it on ?
just some suggestions is all.
DCarr2
Akron NY
I vote sherwin williams oil base problock
Kilz is garbage
Buy a charcoal mask as well
I did my barn a little different, i used this moisture barrier primer from SW. Used 20 gallons. Sprayed the whole barn bottom 8' got 2 coats.
Then used 25 gallons of sw masterhide semgloss 3 coats on botom 8' on coat on tip 10'
Both products i used were latex. And i sprayed both using my graco 390 airless spray right with a 515 tip
Im also almost dine with caulking all the seams and **** joints in the osb. The caulk makes it look finished and will help stop air infiltration
30cal
Illinois
I always suggest using a coat of drywall mud on the OSB first and let it dry thoroughly before applying paint. If you do that you won't see the wood chips in the OSB and it will have a finished look, just like drywall.
Hi Jimmy! :lol_hitti
minytrker
Brenham TX
I did 2 coats of primer and 3 coats of paint. It sucked it up like crazy but looks really good IMO for what it is.
laser3kw
northen IL
don't bother with saw horses. That is just more heavy handling and potential mess.
Instead just lay down painters plastic on the floor (ample (it is cheap), this is your walk zone / paint foot track zone). Lay your sheets down, you can line up two or more depending on room. Then just roll the paint on, like you are mopping. It also is much cleaner, less messy, and less work that way. All the paint drips down,instead of on YOU!
:rocker:
bucktruck
NorCal
Just painted two walls of OSB over the weekend. I used two coats of oil based SW ProBlock primer, and one coat of (Glidden) inexpensive latex white semi-gloss.
I noticed very little lifting of the strands after priming, but there has been a bit after I applied the latex. My guess is that the primer didn't have time to dry properly. We had a cold rainy spell on Sunday afternoon and I applied the primer Saturday afternoon and the finish coat Monday after work.
I might apply a second coat of latex later in the week, but to be honest, it's a garage, and the walls will be covered with shelving, workbenches, electrical and air lines, and some car pictures. Thus, it looks fine, and will look even better after I trim it out.
