painting raised letters
grannyknot
Toronto
In the past I have painted cast in raised letters by hand with so so results, wondering if anyone has come up with a clever way to do this job?
Thanks
ray h
back of house
I've only done one vise. I took a smooth file and flatten the tops of the letters slightly. I then used a quality artist brush. Next time I'll try the padding method as has been suggested.
snapmom
Florida
This is an old one I did. a couple of coats of lite grey primer, maybe 2 or 3 coats of black, a couple of coats of grey-green. then I gently removed the green, I think using 0000 wool, this left the black letters with a grey edge. It took a couple of times to have it end like I wanted. its a bit worn now.
G
grannyknot
Toronto
Snapmom, very nice! I have tried that technique once before but I couldn't keep the steel wool off of the paint around the lettering so it ended up looking dull with the rest of the paint being glossy.
Some good ideas, hard foam covered with thin cloth would work, also like the idea of filing the tops of the leters
I saw a job where someone used a dense foam roller, think it was appropriated from another area, like crafting stencils or some such, which gave an impressively nice finish. I'm not a fan, so didn't pay much attention, but did respect the craftsmanship that got them there.
Nice even coverage, consistent depth at the edges, looked sharp.
imagineer
Most of a lifetime ago, aboard the NY Maritime Academy training ship, we repainted just about everything. When it got to the hand wheels we did the raised letters and symbols using a pencil eraser.
snapmom
Florida
I might have used a high number wet paper, I am getting old and can’t remember
Oregon rock crusher
West of Salem
I like the really fine tip paint pens for raised letters. It helps to try the pen on scrap to get the paint load right. I have to do it first thing in the morning before I get the coffee shakes. I also use high power readers for close work like this. On brass tags with raised letters I paint the whole tag and then scrape the tops of the numbers and letters with a scalpel before the paint gets too hard. Sometimes I have to start over. Ed.
wrenchguy
NW Indiana
By hand.
I used a fine artist brush, cut off nearly all the length with just a few very short hairs left for these very small embossed letters, decorations and numerals. Hundreds of them, the size of the embossing will determine your brush tip size. good luck with your project.DSC05164.jpg
ArcReactorKC
Out in the county NE of KCMO
So I have only done this once but you know the saying "when all you have is a hammer, everything looks like a nail"
I took a piece of cardboard from a diet coke box and a rubber mallet. Laid the cardboard over the letters and embossed the cardboard with the lettering using the mallet.
I then cut the section of box out and scanned it on my flatbed scanner. Traced it in inkscape to make an SVG. Then put that SVG in Orcaslicer and extruded it to be the thickness of the letters height. Printed it on my X1C. Then laid the 3d print over the letters and simply sprayed on rustoleum enamel.
An overdone process but the letters looked perfectly crisp. This was for a finicky customer so I knew I 100% could not freehand it with my shaky hands.
Leviton
Oregon
I enjoy overdone processes. I don't know much about the 3-D printer world and I just want to see if I understand. Are you making a mask that covers everything except the the tops of the letters?
G
grannyknot
Toronto
So I ended up using the daubing method, turned out ok, the problem is the cast letters are in cursive writing so not a lot of space between the letters and the casting is kind of rough.
Filing the tops of the letters helped.
thehorse13
Jefferson County, WV
Another trick is to smooth out the raised lettering during restoration. This will provide a perfect surface for using sponge dabbers or homemade variants of sponge dabbers.
Tostal
The Emerald Isle
I've had good results with a blue Scotts paper towel folded multiple times & using the dab method.
Here's a similar method (with pictures :giggle:) :-
wrenchr
When I was a kid my Dad always had me do this for him. My model building/drawing is why, still to this day I have a steady hand at 47 years old. Old arther is setting in on my right hand though.
LOW1
ontario
Best suggestion for daubing/painting raised letters was in the Vise Thread.
Cigarette ****, filter end.
Now, if I just knew someone who still smokes. :unsure:
Yea. And buying a pack is like $10. Harbor Freight should get into the cig and booze business.
The bad news, if you are painting brown, there are still lots of used ones on the ground, almost anywhere
Tostal
The Emerald Isle
When I used to 'roll my own', I sometimes used to insert a new filter, these were available in any store that sold cigarette rolling papers, iirc the brand name was Rizla. So no need to touch any dirty butts...
