Palm Control ratchets
JeeperAz
SoCal
I recently received a Facom 3/8" palm control ratchet. I love the functionality of this ratchet. I'm assuming it's the same thing as an SK PC ratchet save for the grip on the handle.
Any idea how strong these ratchets are? Can they break loose pesky bolts?
Does anyone else make this type of ratchet.
dink
Plainfield, IN
I have one and I love it...for its size it can handle alot of torque....its worth the money
kartracer55
yeah, they are strong, probably stronger than the standard Ratchets. Check out the site. It says 17 teeth are engaged at once, which means each tooth only bears 6% of the load. I wouldnt worry about it.
Jim
Roadster
Chicagoland
The Facom palm-control ratchets are pretty strong, but I have actually broken one during an engine re-build. The distributor (Griots) replaced it for free, but it took a while due to shipping delays.
skim41
Netherlands
Hi,
They are really, really strong. However you want to break the nuts free with some wrenches or with a torque iron(dont know the english name of it)
skim41
Netherlands
Well, pics might be deceiving. However to me it looks like a 3/8" breaker bar which is 255mm long (approx. 10"). The 1/2" bar is 410mm (approx. 16")
J
JeeperAz
SoCal
Well, I started this thread over a month ago. Since then I have also picked up a set of SK palm control ratchets.
I think the Facom are nicer. Better fit & finish.
Perhaps I'll open up both types of ratchets and take some pics for a side by side comparison.
Roadster
Chicagoland
Coach James said:
OK dumb question here: What does "palm control" mean?
The ratchet directional control is a recessed thumbwheel ring on the outside of the back of the ratchet, rather than a lever sticking out from the back. The thumbwheel reversing mechanism enables easy change of direction while the free-wheeling back plate allows application of steadying pressure without reversing.
Coach James
Sandhills of North Carolina
Thanks Roadster. I've got a palm control Sk, a model #3869, I won in a drawing. I figured the palm control had something to do with the reversing mechanism but I wasn't sure. Many thanks.
Coach
eschoendorff
Roadster said:
... while the free-wheeling back plate allows application of steadying pressure without reversing.
So that's what that thing is for. At first I thought it was just loose! :lol_hitti
ultgar
New Jersey
Here are some more pics of Facom's palm control ratchets
Great ratchets....supply and warranty replacement may be an issue if your supplier drops the line. Griot is already starting to transition to Beta from Facom.
Latest word as of last Friday is that Stanley will not take over Facom distribution until 2008. SD
kartracer55
skim41 said:
Who or what is Griot?
An american thing I guess
hahah
Griots Garage. Its a very expensive mail order place with one or two walkin stores and they are dedicated soley to detailing cars. They sell all sorts fhigh end waxes and cleaners and the like. Most of it is rebadged from other brands, but not one single brand. They take the best of the best from each brand and stick thier name on it, so anything you get from them, you know is going to be top notch. They have torque wrenches branded "griots" but they are made in england by norbar. They sell mag nad aluminum cleaner/polish, and its made by "mothers"... its probably the mest cleaner and polih out there.
Jim
