Panel concentric knockout plug/adapter for smaller size?
gorms
San Jose, CA
I have a large conduit going between both the main panel and sub panel. The wiring will be replaced with one that will not be in a conduit and would need a smaller knockout on each box. Do they make adapters to step down the current hole to a smaller hole? I have seen knockout plugs for junction boxes but they seem to be one size and don't allow for a smaller hole to be punched through them. Thanks.
matt_i
Yes, there are washers which have a "stepped dish" in them for use as a reducer.
If its a huge step that would require multiple washers like above, I would just make a sheetmetal plate, carefully drill a matching clearance hole pattern and secure with round head machine screws and nuts.
LXCam
They're called reducing washers and you can get them in every nominal conduit size.
mm08822
Why not re-use the existing conduit for new conductors?
Why are you changing them out?
ard
There is a failrly large range on the clamps- have you checked to see if a clamp that is a perfect fit for your panel hole is rated for whatever size SER you are using??
