Paper towel holders
d65
Colorado
Hi guys,
Show me what you use in your shop to hold your paper towels. I use plain white paper towels.
MileHighRover
Got it at the local Restore for $15.
didit
S.W. Ontario
Free, from my junk pipe fittings. Hangs over my bench. Not pretty but works OK.
BearsFan315
Portsmouth, VA
just picked up one of these for the work bathroom. works great with all the guys snatching on it and working it to death. easy to load and unload. mounted it on the wall. just push new roll up until it locks in and push up until it snaps out to remove it.
no issues so fr, and for a few bucks, works great. either Wal-Mart or Lowes.
iSpark
Coastal SC
Towel holder you say?
...then at the end of the day, champagne. :)
SGKent
Citrus Heights CA
piece of wooden dowel, one hole in each end and some parachute cord hanging under a shelf. White paper towels from Sams or Costco, and a second one with blue denim towels. Clothes pins on them when the fan is blowing to keep them from unraveling. The cord hangs from a larger dowel like in a closet that has coat hangers on it and a couple other things hanging there.
SARG
Northeast
After trying many different styles ... I finally have these mounted in my several shops .. Search Prodyne on Amazon.
niget2002
Josephine, TX
I have one of the gladiator cleanup caddies. I only have it because I got it at a white elephant gift exchange. The guy had gotten two for Christmas, so instead of returning one, he gave it away.
sberry
Brethren, Michigan
If I was going to buy something its that rubber maid thingy but usually have wanted it NOW.
QwikKotaTx
Seabrook, TX
I'd love to have a bumpstick as a towel holder. The only ones I have are still in good shape but are the stock ones I pulled out of my Dakota.
Sent from my VS987 using Tapatalk
couch67
Ontario Canada
Made a double roll holder that fits between the upper cabs. 24" dowel, right side fits into a hole drilled into the side of the cab. The left end fits into the support as shown in the pic. A magnet epoxied into the left end of the dowel keeps it in place.
TheOtherChris
SE Idaho
I used the HF magnetic for quite a while but now use a Sofpull dispensor that uses those giant rolls that you pull down from the center. Got it off Amazon for $15 with 2 rolls of towels.
Really like it because it is easy to use with one hand.
Wife liked it so much she bought another and had me mount it on the back porch / mud room.
ALinCarolina
NC Piedmont
I made mine with galvanized pipe also. Use some loctite at the elbow and flange so it doesn't sag over time. After this photo was taken I added another longer one to the right to hold a regular towel too. It cuts down on paper towel use when I am just washing hands. The white board is a PVC board.
ALinCarolina
NC Piedmont
^^^^ Are the controls with the red and blue markings to control the faucet on the left?
Yes. Good eyes. I bought this sink at an auction of equipment of a grocery closing down. But I also bought a small hand sink that had knee controlled valves. I removed the valves and faucet, drilled a hole for the faucet and mounted the valves underneath. I glued the plate holding them to the underside with thickened epoxy so as not to make holes in the sink. It worked out great, makes it handy if my hands are really greasy so as not to mess the regular handles.
sberry
Brethren, Michigan
Yes, I change the laundry tubs a little to use a single handle kitchen faucet. There is the typical gage in the well pit but the one at the sink is a thing of beauty.
