upwrencheh
- Joined
- Nov 4, 2015
- Messages
- 8
I just purchased my first vintage vise. It is a C Parker #39. It weighs 52 pounds. What is the difference between this vise and #39X?
Here is what the 39 looks like now. I cleaned all of the grease, rust and old paint off in the electrolysis tank. I straightened the retaining screw as best I could and threaded the handle ends with 1/2-20 TPI and put on some threaded 1.375" ball knobs. Right now it is painted with Rustoleum primer.......Final color undecided
Hey Bagged, I turned the ends of the handle down to 1/2 inch then just ran a 1/2-20 die to cut new threads on each end. I had to undercut the threads a little on the inboard end so the balls would thread on completely. I purchased the balls at McMaster-Carr at their website, link below.....
They have many different sizes, I used 1-3/8 diameter balls. The originals were about 1-1/8 diameter. I used red Loctite on the threads to secure the ball ends, hopefully permanently......
http://www.mcmaster.com/#metal-threaded-balls/=10asne8
Nice old Parker. Here are the numbers on my retainer screw for a Parker 203. It's basically a 5/16-20. From what I understand is that you can still find the tap, but not the bolt. I would work on straightening your bolt if you can.
View media item 49830
As for the handle, I think the knobs were "forged" onto the lead screw. I would look for welder who knows what they are doing to get that firmed back up. The bottom line on Parkers is that if the jaws are in good shape, then they are a great vise.
Take a look at the Vise 101 thread starting on post #117 to see what I went through with my 203.
http://www.garagejournal.com/forum/showthread.php?t=252830&page=6
