Rhyno
Here's my contribution to a topic that is still debated and wondered about.
I built a good parts washer well over 20 years ago, and now I need another one. Unfortunately, the first one was built for someone else, with their money, so I don't have access to it.
I have been needing to do this for a few years, but now it is finally the right time, again.....
I had some parts for a "By-Pass" oil filter that I was supposed to install on my last 5.9L Cummins. That project got "shelved," and I have been shuffling the parts around. The parts included some custom length, fuel/oil rated hoses and fittings. (Fuel is considered a solvent) I also had a common filter and filter housing that is used in the Medium to Heavy trucking industry.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/ByPassFilter.jpg
I got some motivation, and 25% coupon and headed to HoBo Freight. I bought the washer for $94.99 - 25% and also a small "Dolly" for $9.00.
http://www.harborfreight.com/movers-dolly-93888.html
The dolly gave me 4 casters, nuts, washers, and bolts. (plus some firewood with caustic smoke.)
I lowered the parts washer shelf by measuring and drilling. I can't remember the exact numbers, but the shelf will now allow the 17" Five Gallon bucket. While I was there, I drilled and tapped and added some fittings, a 1/4 turn valve, and a short ******. I used Epoxy to secure the fittings to the basin. (Glued and Screwed)
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/DrainValve.jpg
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/EpoxiedDrainFitting.jpg
I cut some scrap MDF, lined the perimeter with some 2x4 scraps and attached the casters from the HoBo Dolly. This was made to have a tight fit and is used as a base. I also mounted the metal shelf upside down. That way there is a stop to keep stuff from falling off of the back and sides.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/18FtCord.jpg
My garage doesn't have a lot of electrical outlets, so I put on an 18 foot cord. (of course another garage surplus) This was after wiring up a junction box so that a switch controlled the electricity to two outlets and also cosmetically covered a hole in the basin. The inside edge was covered by a piece of Aluminum, clamped between 2 pieces of steel channel and "Hammered" into perfection.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/AlumBenderTools.jpg
The Aluminum and junction box were then Pop Riveted together.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/SwitchBoxPopRivet.jpg
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/TestFit2.jpg
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/PlugSwitchWire.jpg
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/PlugSwitchFront.jpg
Drilled and added a grommet for the pressure hose. It just flops around....it does have a brass fitting and kind-of simulates a nozzle.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/OilHoseGrommet.jpg
I used a Submersible Pond Pump from Lowes. I think that it was close to $19.99. It hangs from the pressure line, and is close to 3.5 inches off of the bottom. I didn't add any filtering, other than water filled to 2 inches below the bottom of the pump.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/PumpDrainTube.jpg
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/Pump.jpg
Lid open, simple work light and everything turns off with the switch.
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/Finished.jpg
The lid closed with the light still in place. The lid doesn't close completely with the light clamped on, but far enough for me....
http://i1219.photobucket.com/albums/dd424/BlueLightRhyno/PartsWasherBuild/LidClosed.jpg
And I use Solvent that was purchased from a gasoline style pump at a Fuel/Oil Distribution center. $5.19 a gallon
It might be Stoddard Solvent, Naptha, White Gas, Mineral Spirits, but the pump said "Solvent" and it has a very light smell of kerosene and is clear.
Sadly again, Photobucket's decision to hold our pics hostage have ruined an otherwise very informative thread. Hopefully sometime in the future RHYNO can re-post the pics some other way.
