Peg Board and Bungee Cord
mray312
I don't see this tip mentioned much... Tired of losing your peg board hooks when you grab a tool? Skip the hot glue and try a bungee cord. Weave the bungee around the hook and tie it off in the back of the peg board. It's that simple and hooks stay put. :beer:
LS6 Tommy
Northern NJ
It's a really good idea, except I can't get at the back of my pegboard. Taking it off the wall to add a new piece of bungee every time I add a hook is not something that's likely to happen with a lazy boy like me. :lol_hitti
Tommy
joe_padavano
Northern VA
I've been using these plastic retainers for a couple of decades now.
CJM8515
I just use the plastic retainers. cheap enough and works well.
radio2000
Tommy
Same here. 16' feet of pegboard isn't coming down. Clips mentioned earlier are the way to go for this problem.
gtcs
nm
I used the bungee cord for a while, I just put a finish nail in it and put it through the hole. I guess that only works with the braided cover kind though. I was using them instead of hooks for open ended wrenches many moons ago
cheechi
Triad, NC
the plastic clips don't do a great job if you have the Wall Control pegboard, but zip ties solve the issue easily. You don't need to get to the back of the pegboard with the zip ties you just have to be patient.
hangfirew8
Central Maryland
Real 1/4" US made hooks with a back peg don't need any straps or ties. You have to wrestle them in and out.
Those cheap import hooks with no back peg from the BORG a decade ago, the plastic straps all hardened and cracked on me, and I threw the lot away and bought the real thing online.
It saddens me that they are presented as the solution to a problem that should never had existed.
-HF
Dragfluid
Pillager, MN
-HF
Please educate on how you searched for the good hooks!
PhysicsDude
Dallas, TX
I long ago gave up on the idea of pegboard and just use a piece of plywood with screws, nails, and screw in hooks. Way easier to use than pegboard, with more mounting options.
