Pegboard and wall outlets
Bellaireroad
Fort Worth
How did you handle wall outlets when pegboard is installed over them? Did you make a template to get them lined up? Use box extensions? Any experiences appreciated.
TNToy
West Tennessee
Tape measure, to the close and far sides of the box, and the distance from the top of the faceplate to the ceiling, do a little math, and draw / cut it out with a sharpie and drywall or jig saw
rrich1
Doesn't look pretty but does the job. Hole is cut bigger to accept any cords running to the outlet.
Sent from my XT1254 using Tapatalk
padroo
Chesterton, In.
How far does it have to come out? I would use a plaster ring if it just needed to come out a little.
The trick come in 1/2, 5/8, AND 3/4 sizes.
TonkaJoe
Southern ON, Canada
I added new boxes and outlets so I had the option of setting them out a little further from the existing wall and then framing them back in as the pictures show.
Once the pegboard was cut to fit the wall area it was as simple as measuring out the distances of the boxes and transferring those measurements onto the pegboard.. drill a pilot hole and jigsaw the outline of the device box. Really easy, Just remember the whole measure twice cut one saying!.:thumbup:
Give my build thread a look over, might give you a better idea and more pictures in there.. any questions feel free to ask!.
http://www.garagejournal.com/forum/showthread.php?t=306497
akdiesel
Wasilla, AK
I used Unistrut to make my own power strip. The plugs are Unistut also but you can get single outlets from amazon to make your own. The gray cover is plastic to cover the electrical runs or what ever you have in the strut.
[/URL][/IMG]
mv213
Dallas, OR (the OTHER "Big D")
I mounted my pegboard on 3/4" thick boards. Used a Legrand Wiremold box extension which brought the box out flush with the pegboard. Then mount the outlet and get an oversized outlet cover if necessary.
rharman
SoCal
I framed mine out with 1x2 stock behind the pegboard and routed the opening with a roundover. Will try and post a pic tomorrow.
slow
near Orlando
box extension on my last house. Worked great and gave it a finished look. New house, no pegboard yet. no pictures.
