_brian_
Has anyone used or seen anyone use petroleum jelly as a thread lubricant? I mean not using it as a substitute for anti seize or anything like that, but as general purpose. I am curious on all applications whether it be a dashboard in your car, screws in a metal case, or even assembling furniture where you have a metal on metal thread. I am unsure it is appropriate for external car use like underbody or engine, so unless someone disagrees, that application is assumed poor.
I have tried this on two different applications and it seemed to work fine ... it is all I had at the moment. I used only a small amount like I would applying anti seize or a thread locker. Enough to be there but not enough to clump and make a mess. Although it seemed to have worked fine, I wonder if there are reasons this should not be done and if it might cause issues later. Issues could be something like it dries out and needs to get scraped out, although I think that would not happen.
