Pin Detent or Friction Ring?
BajaBound
Nor Cal
Alright so I pulled the trigger last night on the Milwaukee 2797-22 as I felt it was a great combo with the 4.0 batteries. But this is the base for building a well rounded set of great power tools for the foreseeable future. Well the next thing is the 1/2 impact and the main reason for going with the M18 Fuel line. I would like to know what you guys prefer between the pin detent and friction ring.
Thanks guys!
chipper
Williamsburg, va
Ring for automotive pin for construction or any type work where dropping a socket could be dangerous or at the very least time consuming.. ie...ladders or scaffolding
Trey T
Houston, TX
on impact, friction rings hugs the socket tighter than pin. When impacting, I like the socket to be held tight. however sockets can be a bear to take off compared to pin type.
dankicksass
New Jersey
Pin detent is a positive lock socket retainer. To remove, you need to depress the pin with a tool - a pick, screwdriver, etc. It's for contractors.
Skin
Boston
Its an actual pin that locks the socket on as Dan said in the above post, its not the same as a ratchet detent ball.
The Ratchet Man
Georgia
I like the pin at work but that's cause I can be 100' in the air making repairs. That's a long trip up and down a ladder for a dropped socket. My choice anywhere else is the ring. I really can't stand pin detents but they do have their place.
Wamsutta
Amarillo, Texas
If you'd rather have the pin lock type, make sure you have a pin punch on your person 24/7 to unlock it. Put it on your key ring or wear it around your neck on a neck chain. Have it with you everywhere you go. Don't even take it off when you shower.
BK13
PDX, OR
Really? I would think a pin would be much harder to remove a socket from...
Craptain
Tampa Bay FL
The pin type is easy as long as you have a punch. The ring type can be a real pain sometimes and will just fall off when you don't want it to. :eek:
finn
The UP, God's country
I have a snapon air impact with a pin. It is an unmitigated pain in the azz to use for automotive work.
I usually reach for my 30 year old Black & Decker so I don't kave to deal with that pin
