Pioneer install complete
ticklechicken
Florida
I finished my install three weeks ago and wanted to give a report. First, the shop details:
  • Carolina Carports metal building
  • 24 x 45 x 10
  • 1,080 sf
  • Closed cell foam (2" on walls, 3" on ceiling)
  • 3/4" plywood walls on furring strips
  • Insulated roll-up garage door
  • No windows
The install was easy. I found the manual to be surprisingly good. I was nervous about cutting the lines and making my own flares, but that was easy. I used a cheap $25 tool from Lowes. Bending the copper lines was a nervous process, but the copper seemed to be much more durable than all the warnings would leave you to believe.
I installed the inside units so that the bottoms were 8'2" above the floor. This gives me the ability to place typical lumber against the wall if I need to. This placed the top of the unit pretty close to the ceiling, but it was within the specs in the manual.
For the outside units, I used the Pioneer wall brackets. Many posts on GJ complain that they're too flimsy, but they survived 80 mph winds during Irma last week so I'd say they're strong enough. I used unistrut to attach the brackets to the building. My posts are 5' on center, so I had to use two 6' pieces for each outside unit.
There was no specific instructions for routing the inner/outer signal wiring when you get near the outside unit. The pictures I've seen show the wiring exiting the flexible line cover and running to the electrical connection at the top of the outside unit. I didn't do it this way. I kept the cable in the flexible cover all the way to the refrigerant line connection at the unit bottom. Then I cut a hole and ran the cable in flexible conduit up to the top connection point. It wasn't that much extra work, and I like the way it looks.
I installed two of the 18k ++ (SEER 21) units. I considered doing a dual head unit, but I thought the install wouldn't look as nice. I didn't want refrigerant lines running all over. It's also nice to have a little redundancy if one of the units fails. I picked these up at the high seer distribution center near Miami. They were helpful and walked me through the install process. They also gave me the name of an a/c guy near me who works with these units. That was helpful, as the guy came out one evening and evacuated/charged both units for only $100.
I had a lot of trouble trying to decide how much cooling I needed for my building in my climate in Florida. There wasn't much useful information on the web. It takes about 50 minutes to lower the shop temp by 10°. I lowered the set point to the minimum, and the shop was down to 70° pretty quickly. I stopped the test then, but it could have got colder. It was in the mid 90's outside during this test. Next, I left the a/c's off for a few days, and then turned only one of them on with a setpoint of 75°. It was in the low 90's outside, and the single unit got it to 75° inside. Bottom line is that you don't need this much cooling in a well insulated shop. It is nice to have the quick cool capability though.
soob
Nice. Now peel those ugly stickers off before they get to be stuck on there.
roadrunner255
Driftwood, Texas
Nice install, I am in the process of installing 2 1.5' as well.
I am using emt and running 12 g solid THHN to the disconnect boxes.
Can you share a ground between the 2 20 amp breakers as long as the breakers are on phase a and b or would I need to run 2 grounds?
Thanks!
T
ticklechicken
Florida
Thanks!
The 18k (1.5 ton) units are all 240V, so they will each be on both phases in your panel.
As I understand it, all the circuits in EMT can share a single ground. The ground wire must be sized for the largest circuit. That means you can use a single 12g ground for both of the disconnect boxes.
PoorOwner
CA
Looks good but I am pretty sure one of them would have done the job.
You got a really good price for the guy to do the leak and startup
co-pilot
houston tx.
looks great!.....I just did my small 450sf. garage with an 1800k & it cools down quick, your install looks nice congrats:beer:
Robertt253
  • 24 x 45 x 10
  • 1,080 sf
  • No windows
Hey, how does the brackets mount to the unistrut? I have 55 inch on center on my legs so I need to go this route.
Thanks
Crowbarman55
Love my MrCool MS I'm my garage.
Maybe I missed it but, where are your drain tubes?
There are several different grade of soft/ductile/annealed tubing. Type K has the thickest walls and is typically used for refrigeration/AC. Type L is typically used for commercial or underground. Type M is used for residential plumbing.
