Pipe facing disc fabrication question
hbabler
North Texas
So I am trying to piece together a non metric threaded version of this facing disc set as SS customs does not offer a standard threaded version:
I think if I take this backing plate and thread it 5/8 11 I can accomplish the same thing?
So now the real problem I have no machine tools. I was thinking about ordering a short piece of brass round stock and cutting it down. Then I could drill it through and thread it. The only issue I can think of is if I need to chamfer the edges to fit into the backing plate. I want the center nut to stick up a bit so it helps locate the pipe on the grinder
Any ideas or thoughts?
RoninB4
Under My House
-"So I am trying to piece together a non metric threaded version of this facing disc set as SS customs does not offer a standard threaded version"
-You haven't stated what you're trying to adapt to/from. Maybe you could also make a legible sketch with some dimensions because you "want the center nut to stick up a bit so it helps locate the pipe on the grinder". So maybe you could help to define "a bit" too. Not trying to be a jerk here but your request is a bit vague. There are store bought adaptors out there, I even purchased one for my Makita grinder. You could also take @no704 suggestion and use a flap wheel.
PCustoms
VT
Is this just a set of "sized" backing plates?
How does it center to the pipe?
Why do you need it to center?
H
hbabler
North Texas
Very good questions I appreciate you taking the time to help me.
Honestly the more I think about this the more it's a solution to a problem I don't actually have.
I was going off of a picture that SScustoms has on their website that I didn't share (Oops). The reason that I was wanting the brass piece to stick up a little proud of the sanding surface was to keep the pipe from rolling off the grinder as I have had issues with in the past.
However I think I will just get a larger resin fiber backing pad and use it instead. That way I have more space to sand with and it won't tend to slide off as much.
The more I look at it yes it is. I had it in my head that it would be more useful than I think it actually is. Your questions helped me think it through and saved me some money!
Thanks guys!
Beerhippie
Far NE Oregon
Without some way of maintaining the pipe end square to the disk, I see no advantage over a flap disk or fiber disk and backer.
If you're trying to get the end of the pipe to perfectly square for fusion welds, a vertical disk grinder with table and v-block is much better.
dr_clyde
Holland, MI
Without knowing what it is you're trying to accomplish, this seems like a solution to a problem that doesn't exist.
If you're trying to square crooked cuts for general fab work, just using a fiber disc on a standard backer will work fine.
If you're trying to prep pipes/tubes for orbital welding, you really should be using something like these.
When I did a lot of sanitary tube welding, I did it all by hand, no orbital. So I didn't need a squaring tool. I used cut blocks to cut the tube square, touched it up with a file then welded.
H
hbabler
North Texas
Thank you for the wisdom @dr_clyde
I’m just going to order another fiber disc backer and some additional choices grit wise.
I was definitely overthinking for what I need
