They will replace stuff much like Sears will for Craftsman itemsDR_K13 said:Got the HF paper today in the mail, I noticed that on all the Pittsburgh hand tools, it now says " Lifetime warranty ". Has it always been that way? I have never seen it advertised. I have a pry bar that I would like to get replaced.
eschoendorff said:They will replace stuff much like Sears will for Craftsman items
I got some pry bars ( should call them bend bars ) and some cheap screwdrivers that I keep in the house. The safety wire tool I got broke the fist time I used it.mulepackin said:I've noticed it in the ads for sometime. Never been brave enough to try em out though.
eschoendorff said:Just FYI... I have never heard anything good about HF prybars, but there is plenty of negative comments about them on the internet. You might consider upgrading to the Craftsmans on sale now through the Club. The Cman pros are even nicer and will likely not break....
Actually, I use HF prybars a lot. Their great for light-duty prying, like tugging on a fuel-line to pull it over so that the clamp lines up with the bolt hole.Deafautotech said:for weekend warrior as harbor frieght is ok but for me as professional technician and need high quality tools so i dont have to break all tools and replacement it every week.....
TNToy said:A set of three was like forty cents.
DR_K13 said:I got some pry bars ( should call them bend bars ) and some cheap screwdrivers that I keep in the house. The safety wire tool I got broke the fist time I used it.
I had the same results except with the 21 mm impact socket ... using a 24" Snap On breaker bar to loosen lug nuts, it cracked; took it back to HF store and they told me they needed the receipt; ended up sending it back to HF Corporate Offices and they shipped another socket a month later ...MAD said:I have a set of H.F. Pittsburgh 1/2" drive deep metric Impact sockets. The 17 mm, 18 mm, and 19 mm all cracked after only a few uses with a not very powerful impact gun. In fact, the 17 mm broke on the first try with a breaker bar taking wheel lugs off. I have not bothered to use (or crack) the rest of the set.
Some of their stuff is ok some is junk. Quality control is not their strong point- to say the least. Some of their stuff is hard to resist if you are willing to take a gamble- it is just so inexpensive. But in my opinion, it is just not worth it for any frequently used, common sized wrench, socket, or ratchet or screwdriver. The higher quality alternative from Craftsman, Ebay, or even the Stanley made stuff from a big box store is worth a few extra bucks. Especially if you buy it on sale.
Willy Victor said:DR I almost bought one of those safety wire pliers, thanks for the heads up.
Willy
