Plasti-Dip - Electrical Liquid Options to Insulate Battery Terminals
mobiledynamics
Gotham City
I've racked my brain and yet to find something...
On a bind, I picked up a replacement battery while out of state traveling...
It needed to be a reverse post battery, but it was not in stock. So I just got standard posts...
Cable in the vehicle reaches FINE to the new battery BUT right above it, there is a metal frame that is just a hairs breath between the post. Had a couple of bumps and when the posts touched the frame...it would create some weird electrical issues, in which upon further inspection, I verified the problem as such.
Is there any sort of liquid brush on *product*, I can brush ontop of these posts to insulate them without making it look completely HACK...
For those confused, just to clarify, battery in in the back off the trunk and the frame that is described above, is the frame that mounts above it, which serves as the mount for the air compressors for the suspension.
hangfirew8
Central Maryland
rlitman
Long Island
I was thinking something of thick viscosity that I could just brush on and it would not run off
Unfortunately, what you want, does not exist. The thick "dipped" plastic handles on tools like Channellock use a chemical called plastisol. It is heat cured, not something you can brush on, so it wouldn't work in your application.
The brush on and dry stuff like plastidip dries to a pretty thin film. Nothing I would trust to this use. It rubs off easily, and just a little contact with metal, and I'd expect it to tear. Then the sparks start flying again.
The answer for you is the solid plastic covers. There are several types out there. Find what fits best.
hangfirew8
Central Maryland
I agree the OP's desired solution does not exist. Almost anything he puts in between will eventually rub through. Maybe a sheet of fiberglass will last the longest and still insulate.
Perhaps the best fix would be to use a shorter battery, or relocate it altogether.
ChevyEFI
Phoenix, AZ
The plasti-dip liquid holds up but isn't going to prevent abrasion or cuts over time.
It would be safer to clearance the metal frame a bit until there's more of a margin for error. A short could damage components, especially in a newer vehicle.
gungatim
west mich
there's a product been around for decades called "liquid solder". available at hardware stores most everywhere...but in your case, I would not use a product that thin.
Have the same issue on my old ironhead Harley, I cut some rubber sheet (actually those self stick rubber anti-slip pads they sell at HF) and stick that directly on the frame where the battery terminals are. it's about 3/16" thick, and does not look hack...
404
Mass
Some rubber is actually electrically conductive (sort of) so what ever you choose check it with an ohm meter first.
djb2
Redwood forests
You don't want something that is merely an insulator. Most materials are reasonable insulators, and 12V isn't going to put stress on any material.
Instead look for a material that is abrasion resistant and puncture resistant. That's how a failure will occur.
Shiftless
East Bay SFO
Get the right battery and fit it. Not worth saving a few $$ if your car then catches fire.
^^^^^What he said ^^^^^
If you insist on a fix, consider the 1/8 inch pieces of rubber sold in hardware stores used to make your own plumbing gaskets. From a spot well away from the positive terminal, pop rivet a piece to the nearby metal bracket.
If the bracket gets shorted, it will ground your positive terminal, send about a hundred amps or more through who knows where in your electrical system and possibly set your car on fire.
toplessHO
central florida
I have plenty of pieces of high voltage electrical mat
its about 1/4 inch thick
tell me how big a piece you need and just pay for postage
skruft
I agree, if you can't get the right battery, something substantial needs to be there or the clearance needs to be increased.
