Platform attachment for ladder
branimal
Is there an attachment for this ladder to make it a platform. I'm taping drywall and it's a pain using the ladder as an A-frame.
Thanks guys
DHCrocks
Hawaii
looks similar to the gorilla ladder I have, it came with a bracket to lock the lower legs in place so you can use the top section as one "A" frame and the bottom legs as a second. I also have a little giant that the lower legs can lock into themselves using the locking pin.
then just use some 2X10's or whatever you have to make a plank. they do make aluminum planks but they are pricey.
mechanic217
Little Giant makes a platform to stand on ,otherwise another ladder and a plank?, or baker staging?
branimal
I've got some leftover 3/4" plywood. Thinking 2 layers screwed to one another might do the job.
Thanks
branimal
Does Werner make tool buckets for these type of ladders?
jakemac
New England
That's a knockoff of LittleGiant's design.
Remove the legs, place them together and lock them together with with the swivel locks.
Then open it up into an A-frame.
Now you have two frames to put a plank between to stand on.
This is an intended use for this design.
Zeke
Thanks
You'd be better off using the plywood with some 2 x 3's in between at the edges. Otherwise it will bow. I doubt it would ever break but who wants to stand on a springboard?
Miss the Pontiacs
Saskatchewan Canada
Sturdy ladders make a nice platform ladder. I have a 6 and a 10'. When I need I use the adjustable Sturdy plank to run between them. The platform gives my helpers the piece of mind that they are safe and can concentrate on what they are supposed to be doing.
branimal
Werner makes an extendable platform but i need something a little smaller. Maybe 4-8'.
Anyone know of anything?
branimal
Werner makes a 6-9 foot platform. Online it's about $140
