Please comment on my proposed Air Outlet setup
kylek350
Chicago, IL
I plan to use 3/4" Copper pipe to distribute air around my garage. What do you think about my proposed air outlet setup? I plan to have these located around the room, spaced to similarly to electric outlets.
3/4" Copper distribution to tee fittings, then 3/4" to 1/2" NPT female adaptor. From there, I will screw in 1/2" to 1/4" Hex Bushings, and finally 1/4" male Universal outlets. This will give me the flexibility to go between 1/4" and 1/2" at the outlets (if the need arises) without re-soldering in the future.
The hex bushing I found at my local Home Depot is galvanized steel. Is that advisable when connecting to Copper?
Thanks!
K
kylek350
Chicago, IL
I take it brass would be a better material for the bushing than galvanized steel, correct?
dr_clyde
Holland, MI
Should work just fine.
If you're worried about galvanic corrosion, just slip a little anti-seize on the threads after you put on thread tape.
machine_punk
Napa Valley, California
You haven't given us the size your shop, but you COULD go with 1/2" copper distribution pipe, unless your shop is HUGE. (Don't get me wrong, for a few dollars more, I'd go with 3/4" too).
I'd use some sort of soft hose between the pipe and the compressor too, to decouple it from the vibration. If you don't, then I'd definitely BRAZE the pipe, instead of solder. The solder may not hold up to the constant vibration of the pipe. I seem to remember that when I was researching a copper system, I wasn't pleased with the percent of safety factor with just soldering (it was rated for enough pressure for the system I planned, but it didn't have that "twice the system pressure" safety factor I prefer in compressed air systems and lifting systems.
I'd put at least a filter at each outlet. This is the little 'glass bowl' thingy. It has a sintered brass filter inside. It does a WONDERFUL job of removing water from the air--as long as you place them far enough away from the compressor. I've tried placing these right at the compressor, but the air is still too warm and able to hold a lot of water. Once you get a few feet from the compressor, the air cools down and these little filters do a great job of taking water out of the compressed air.
You could use a 90-degree fitting to install the filter horizontally.
In the places I work the most, I like to have at least 2 outlets, so I can have 2 tools set up at at the same time. OR, you could build a little manifold to plug in, whenever you want more than one tool ready at a time. (I have both options at my shop...both the compressor and remote outlet have a pipe-fitting manifold with two quick-disconnects each. I also bought a little aluminum manifold block online and have a one-input, 3-output manifold I can attach, when I want more tools working at the same time, or I am visiting someone else's shop).
My other thought is that I was headed in the same direction you are, but now I'm going a little different route with my setup. I think I'd rather have a small number of hose reels, mounted high, than have a lot of outlets, mounted low. A 35- to 50-foot hose reel in each corner can reach just about anywhere you want to go in your shop and doesn't take up critical wall space with outlets, unless you have a HUGE shop. Even in a huge shop, I'd rather have fewer hose reels, mounted higher, than more outlets, mounted lower. Wall space at waist height is at a premium. Higher mounted reels stay out of your way and keep hose off the floor as much as possible.
I wouldn't go straight down into the quick-disconnect coupling. Any moisture you have in the air will go straight into the tool. I'd use a "T" where you show the quick-disconnect, run a filter horizontally off the pipe and add "T's" and elbows to put a couple of quick-disconnects on each filter. Then, run a couple more feet of pipe straight down through the "T", with a tank drain valve at the bottom (either a 'pull ring' style, or the standard valve at the bottom of a compressor tank, a more-expensive ball valve, or an electric-auto-timer-valve, if you really want to go fancy). This will allow a lot of moisture to drop directly into the tubing extension and you can empty the extension daily, while the system is pressurized.
For the price, you may want to look at what RapidAir has. They have a pretty extensive 3/4" piping kit for $200. You'd likely need to add a few components, but I've definitely considered going that route too. You could really get away with their kit with smaller tubing, for about $75, unless you have a humongous shop.
You've got a great start to your planning. Looking forward to pics, whatever you decide to do.
Kev
K
kylek350
Chicago, IL
Thanks for all of the great info, everyone!
So here's the lay of the land: I have two adjacent garages, one being a 3-car (30' W x 22' D, and the other being my shop (~15' W x 30' D with a 14' ceiling). The compressor (IR 60 Gallon) is in the 3-car garage.
I'm going to connect it by 3/4" rubber hose to a Copper cooler dryer that I plan to build. For the cooler/dryer, I'm thinking I'll do 3 or 4 up/down runs of 6' or so with drain valves at the bottom of each run.
From there, I plan to then have two trunks, one serving the 3-car garage, and the other serving the shop. I'd like to have separate regulators/filters/oilers/desiccants per trunk.
Which such a cooler/dryer setup as I plan to build, is it still advisable to have additional drains through out the trunks even if I'm running desiccant dryers?
sberry
Brethren, Michigan
I don't care for hydrants and moving hoses. I like a real or fixxed whip. It just adds another coupler in the line that really isn't needed.
mbshop
visalia ca
Yup, a water filter about 2 or three feet away from the comp and then down the line before the outlets a u setup with a drain plug at the bottom should take care of most moisture issues in the line. If painting then that is a whole nother issue.
sberry
Brethren, Michigan
I have a reel with a small filter/reg ahead of it just for paint. There is a valve ahead of this whole leg to shut it off unless its needed.
DC73
Lubbock TX
I did something similar when plumbing my workshop for air. I would recommend a brass bushing instead of the steel one. I ended up opting for fewer drops in the shop by going with a 100' hose reel at one drop and 25' hoses at the other drops.
I also plumbed each drop with a shut off valve and a drip leg with another valve. Even though my system doesn't generate much moisture at all, I like being able to close the shut off valve and then use the drip leg valve to depressurize the drop which keeps pressure off the hoses when not in use and makes it much easier to connect tools to the hoses.
DC
Viz
I also use a shut off valve at each coupling outlet. You never know if you'll need one there until you don't have one.
